Boost question
Results 1 to 4 of 4
Thread: Boost question
    Moderator Array NeverEnuff's Avatar
    Nov 2006
    TX
    3,942
    Default Boost question
    So guys. I converted my 2000 Expedition Eddie Bauer to superCharged Expedition Eddie Bauer! Found an almost complete kit off a Lightning. Got it all on, and drives and runs great. Tuned it up nice and safe. Stock lower pulley, stock upper pulley. All from what I know and read on forums, google, etc etc, I should see 8-10psi. I know my compression is just a tad higher than stock Ls, but with that....I want your input.
    Like I said...stock blower setup, previous owner said he stripped the rotors and did a little porting in the intake. Doesn't look too much like porting as I would say polished or cleaned up. Problem is, Im only seeing 3/4 psi, and on the top end sometimes 5lbs at 4500-5k rpms. This is almost half of what I should be seeing. I thought maybe I got the HD truck pulley for less boost, but nope. Checked right in at 2.93" or so.
    Now, Only think I can think of is the ported intake/blower is breathing easier so less boost, and also, I have a set of Comp 270s installed as well. I knew boost might be a little lower, but half?!?!
    Any ideas? I have a 6lb Metco Lower on the way here soon...just wanted some opinions. Never built/tuned a PD/Roots combo before and so far I love it.
    INput? Bypass? Blower? Cams?
    Thanks
    Matt
    Wow, can't believe no one has responded to this. I don't think too many people frequent this part of the site. Anyhow, what kind of intake setup are you running? Positive displacement blowers are very sensitive to restrictions on the inlet side of the blower. Also there is the possibility that the bypass valve is hanging open, supercharger belt slip, or possibly too much overlap on those 270s (I'm not familiar with the specs). Hope some of this is helpful if you haven't already sorted it out.
    Junior Member Array
    Dec 2006
    Mesquite, TX (Dallas)
    5
    Did you figure it out? first thing I'd check is the gauge. Then check for leaks at the intake.
  6. #4
    Nov 2006
    TX
    3,942
    Sorry guys. Took the kit off and sold the truck months ago. But thanks for the input.
  7. Remove Advertisements
  1. Boost question about my KB
    By SlowImport in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-08-2010, 01:20 PM
  2. Question about boost?
    By BURT REED in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 02-28-2008, 07:20 PM
  3. Boost/CR question
    By Gonzo71 in forum Whipple Tech
    Last Post: 01-20-2008, 07:26 PM
  4. boost question how much?
    By 03cobravert in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-01-2006, 09:06 PM
  5. Question about boost on 05.
    By jones in forum 2005 - 2010 Mustang GT
    Last Post: 05-01-2005, 12:29 PM
