The new build consist of:
WAP Aluminum Block
DSS flat top pistons
Ultra Light I beam rods
Cobra Crank
TFS 44cc heads
TFS dual valve springs
Jessel Aluminum Followers
Custom Cams
TFS Track Heat Intake
42# Injectors
P-Mas MAF
COP conversion
Meziere Electric Water Pump
Innovators West 10% underdrive Crank damper
March Cobra R alternator pulley and larger diameter power steering pulley
Mac Long Tubes w/ Pro Chamber
Mac Catback
Hanlon built face plated TKO500
Spec Clutch
Fidanza Aluminum Flywheel
I'm pretty excited by the results. I got to take it around the block for the first time yesterday and it feel incredibly strong and the dyno numbers seem to back it up.
The second set of numbers are for comparrison and are from when the car has bolt ons, PI head swap, and comp 270 cams.
WAP Aluminum Block
Cobra Crank
TFS 44cc heads
Custom Cams
42# Injectors
P-Mas MAF
COP conversion
Mac Catback
Spec Clutch
