ECT/IAT sensor voltages
Results 1 to 4 of 4
    Moderator Array
    Jul 2006
    San Jose, CA
    1,478
    Default ECT/IAT sensor voltages
    I am in the process of developing a series of gauge products for 94-98 Mustangs and need a little data to make sure that they will work with 94 & 95 Mustangs. The first product will replace the clock with a color OLED module with Clock, ECT, IAT, Oil Pressure, Fuel Pressure and voltage displays.
    My 96 Ford Emissions Manual gives me the voltage and resistance specs for the ECT and IAT sensors. Based on that data, we can tap into the ECT and IAT sensor signals to show those values. I am hoping that the 94 & 95 PCMs use the same sensors and voltages.
    I dropped by the local Ford dealer today, and they told me that, when Ford put all this data on-line for their mechanics, they threw out all their old hard-copy manuals, and now Ford no longer has that kind of information on-line for their mechanics. He seemed pretty disgusted and felt bad he could not help me.
    So I need someone with the equivalent of my 96 emissions manual to tell me what the specs are for the 94 & 95 Mustangs.
    For completeness, here is the data for the 96-98 cars:
    96 Ford IAT/ECT Sensor Data
    *F *C Volts K Ohms
    248 120 0.27 1.18
    230 110 0.35 1.55
    212 100 0.46 2.07
    194 90 0.6 2.8
    176 80 0.78 3.84
    158 70 1.02 5.37
    140 60 1.33 7.7
    122 50 1.7 10.97
    104 40 2.13 16.15
    86 30 2.6 24.27
    68 20 3.07 37.3
    50 10 3.51 58.75
    Thanks in advance.
    Senior Member Array Magic's Avatar
    Apr 2005
    North
    3,286
    Sounds like a product I might be interested in for my 95.
    I'll dig around to see if I can find any info for you.
    Apr 2005
    North
    3,286
    I found this in another forum, where a guy asked a question regarding his 94 mustang GT.
    Also I did some part number cross reference, they are the same sensors as used on the foxbody for a 94-95 5.0L.
  6. #4
    Moderator Array
    Jul 2006
    San Jose, CA
    1,478
    This is great information. Thanks for the data. It proves that the sensor is the same from an electrical perspective. Assuming the 94 & 95 PCMs use the same pullup resistors, (highly likely) then the circuit can be the same for 94-97 cars.
    I have the software nearly done, and am starting to build a prototype. It is much easier software than the make-the-gauges-real circuit I am also still working on.
    Mark
  7. Remove Advertisements
  1. ECT Sensor, what the ???
    By BlueScreen in forum 1996 - 2004 Mustang GT
    Last Post: 04-15-2012, 09:03 PM
  2. IAT high and IAT sensor B vlotage Low Issue
    By 5.0 Mustang Man in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-14-2008, 09:02 AM
  3. Why does my xcal 2 show 100 t at idle for iat and ect?
    By rossmacd in forum Tuning and Diagnostics
    Last Post: 08-11-2007, 10:32 AM
  4. ECT sensor location?
    By SALEEN039 in forum 2005 - 2010 Mustang GT
    Last Post: 12-07-2005, 09:08 PM
  5. LM-1 PCM pin # for IAT, MAF, TPS, and ECT
    By que4dog in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-06-2005, 07:33 AM
