Coolant Cross Over Delete by MMR
These Fittings allow you to remove the Coolant crossover metal pipe on ALL 4V applications. Radiator Hose Fitting has 2 threaded holes on top and bottom for factory and aftermarket water temp sensors - central location gives true coolant temps, not just left or right bank. All fittings use -12 AN size - no leak prone NPT fittings. Integrated hold town tabs on cylinder head fittings prevent spinning when tightening. Includes all parts shown. Great for custom applications where plumbing space restrictions exist. Can be used with Braided or Pushlock style hose and fittings. Available with or without radiator fill/cap adapter. When purchased with filler option the large factory radiator reservoir can be removed. Factory radiator hose barb size allows mounting in any location including directly to the radiator . Upon request also available with AN16 instead of Hose Barb. 100% CNC Machined and USA Made by MMR
Also now available for:
2005-2010 3V
2011-2013 5.0 TiVCT
Kit includes multiple schematics for plumbing options.
MMR inline thermostat housings also available for custom applications.
Pic with a custom 4 way block:
Click here to order: $199 to $389 http://www.modularmotorsportsracing...rch_in_description=1&keyword=crossover+delete
2005-2010 3V
2011-2013 5.0 TiVCT
