Results 1 to 15 of 49
02-20-2013, 12:46 PM #1
- Join Date
- Sep 2009
- Posts
- 303
RLongo Build Thread - 97 Cobra 83mm Bullseye
Well I've made enough progress on the car that I can start a build thread. It’s a 97 Cobra that will be street/strip car, not a dedicated race car. I will still maintain A/C, Heat, Radio, P/S and disc brakes.
It will have a 4.6 4V DOHC with full race “C” Heads. Engine is being built and assembled by Tim Eichhorn of MPR Racing in Boynton Beach FL (Mustang Performance Racing), with head work by Kris Starnes. The power adder of choice will be a Bullseye T4 83mm with a 87 mm TW and race cover. Trans will be a built 4R70W, with FB Transmissions MVB, L/U and O/D. Converter will be a UCC unit. Fuel needs will handled by a Lethal Performance/Division X 1400hp return system and a 03 Cobra tank, with ID1000 injectors via Sullivan fuel rails.
Rear end is Ford 9” with 35 Spline Moser axles, locker differential, UPR Coilovers w/ Strange Adj shocks and GT brakes (to clear 15 x 10 drag wheels). The Front suspension will be all UPR including their coilovers and Strange adj struts. The car will also have Wolfe Racecraft thru-floor subframe connectors and 8.50 certified chromoly cage and parachute, custom built by David Dodge at TigVision Welding (West Palm Beach FL).
I will update as progress continues.
Here is how it started a year ago when I picked it up. 130k miles, no mods ever done to it.
Inteior Demo for Cage
Subframes Installed
Parachute
UCA Reinforcement
LCA Reinforcement
Rear Suspension
Engine (Out with the old)
Engine New Setup with “C” Heads
- - - Updated - - -
Hotside
Sullivan Setup
New HoodLast edited by rlongo; 02-25-2013 at 09:58 AM.
Sponsored Links Remove Advertisements
02-20-2013, 01:22 PM #2
02-20-2013, 01:35 PM #3
- Join Date
- Sep 2009
- Posts
- 303
Thank you sir!
- - - Updated - - -
Engine setup consists of Teksid block, stock bore, forged cobra crank, oliver billet I-beams, Diamond pistons with a CR of 10.35:1. Heads are fully ported and polished with Bullet racing springs and retainers, manley SS Valves and Ford GT cams. -
02-20-2013, 07:54 PM #4
this is one freaking clean cobra!!!! and the built
i'm bringing up some popcorn and follow this built!!!! -
02-21-2013, 08:27 AM #5
- Join Date
- Sep 2009
- Posts
- 303
hahaha. Thanks!!
02-21-2013, 11:15 AM #6
- Join Date
- Oct 2008
- Posts
- 390
Very nice build! Look forward to following the progress
02-21-2013, 02:56 PM #7
Ron, that thing is looking good!
02-21-2013, 05:57 PM #8
very nice looking car! You have the best in the business right around you (us) with Tim @ MPR and Dave @Tigvision. I cant wait to see the car at the track soon!
Rick -
02-22-2013, 12:40 PM #9
Screw the car, that's a badass engine hoist. haha kiddin, man this is going to be sick. If you can hook, this is going to be a very fun street car.
02-23-2013, 11:10 AM #10
Great looking build! Who put together the hot side?
02-25-2013, 10:03 AM #11
- Join Date
- Sep 2009
- Posts
- 303
Thanks!!
Thanks man. Saw your "Todo" list for yours on FB!! Looking forward to seeing the updates.
Thanks!! Looking forward to just driving it again....and then some track run!
The engine hoist is the best part of the build. I work on some better pictures. hahaha. It should be able to give a TT 03 a run for it's money
The hotside is from Revolution performance out of S. Florida. -
02-25-2013, 11:10 AM #12
02-25-2013, 11:26 AM #13
- Join Date
- Oct 2008
- Posts
- 390
02-26-2013, 09:59 AM #14
02-26-2013, 10:07 AM #15
- Join Date
- Oct 2008
- Posts
- 390
With a lockup converter it shouldn't be too bad. Obviously mileage will suffer some but the car will feel like a rocket. I'm sure with the 57s it is probably quite responsive though?
97 Cobra single 76m Turbo Build : CG Fab hot side
By 03bluemach in forum Turbo ModularReplies: 19Last Post: 08-25-2012, 09:22 PM -
4v cobra 83mm turbo kit
By 95mustang_gt in forum Power AddersReplies: 4Last Post: 05-02-2012, 03:46 PM -
New build thread.
By guarnibl in forum 1996 - 2004 Mustang GTReplies: 8Last Post: 02-25-2011, 12:31 AM -
97 Cobra Build Up
By nightsun in forum 1996 - 1998 SVT Mustang CobraReplies: 5Last Post: 02-14-2011, 10:47 PM -
My 1998 GT/Cobra build thread
By BOSSisback82 in forum 1996 - 1998 SVT Mustang CobraReplies: 11Last Post: 11-05-2009, 12:42 AM
Best Black Friday Automotive &...
