Every Raptor owner knows that the 100mph speed limiter is no fun! :thongue2:
We all know that this limiter can be raised or removed with simple tuning, but this does not address the issue of the weak factory drive shaft...
The stock Raptor Drive shaft is not designed for high speeds and runs the risk of coming apart which can be very dangerous. This is do to the poor balancing from the factory and flexing of the thin walled aluminum.
Sooo what can we do :dunno2:
Upgrade you Ford Raptor's stock drive shaft to an Aftermarket Raptor Drive Shaft.:rock:
JDM Engineering offers an upgraded Raptor aluminum drive shaft that is manufactured by Axle Exchange. Axle Exchange makes all of our drive shafts for our race and other high speed applications. They have never disappointed!!
Remove your Raptor's speed limiter with confidence and upgrade you stock drive shaft with this precision made unit from Axle Exchange!! Not only will this Raptor Drive Shaft hold up during high speeds, it will also improve you driving experience. This light weight Raptor Drive Shaft will improve you trucks acceleration!!
Heavy Duty one piece 4" Aluminum welded driveshaft.
Built in America using American products.
HD slip yoke, HD Dana Spicer joints, Dana Spicer Flange, Heavy Alcoa Aluminum tubing and
High Quality machined weld yokes. Hi-Speed Balanced and Straightened
What are you waiting for?! Order NOW at only $625+S&H
Ford Raptor Drive Shaft
