Max boost on stock 1 bolt tensioner?
Results 1 to 4 of 4
    Default Max boost on stock 1 bolt tensioner?
    What's the max boost you guys are seeing on a 2.6h 2v with the 1 bolt tensioner without bending or breaking it? I've ground off the travel stops on mine and on 20lbs at wot my tensioner is hitting my idler and destroying belts.
    Senior Member Array Last Man Standing's Avatar
    Jan 2006
    Chesapeake, VA
    417
    I have a 2.1 KB with custom inlet and see 20psi at the track. I have a 1 bolt tensioner and 6 rib belt and have no problems. I run a 7.75 lower, 3in upper and shift at 6300rpm, thats 16,275 blower rpm. I run Napa/Gates belts and change them every year. Also I inspect the grooved pulleys, sometimes they get rubber buildup in the grooves, which can cause problems. I also run the shortest belt I can. I also swaped out my right side blower idler pulley for a 90mm for more belt wrap around the blower pulley. I don't understand how your tensioner hits the idler ?. Maybe a picture of your belt drive system will help.
    It's because there's no travel stop on the tensioner. So when it's all the way closed it touches mg idler. Im going to get a new tensioner and a 90mm idler. See if that helps. What length belt are you running? I've got the KB 7.5 lower and 3" upper.
  6. #4
    Jan 2006
    Chesapeake, VA
    417
    The part number for my belt is 25-061110. It was tight to get on. You want to run the shortest belt you can. Also adjust your idlers to get the most belt wrap around the blower pulley.
  7. Remove Advertisements
  1. Max boost on stock cams.
    By Last Man Standing in forum 1996 - 2004 Mustang GT
    Last Post: 01-29-2012, 04:23 PM
  2. stock cobra boost max
    By streetracer612 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-22-2009, 11:46 AM
  3. max boost on stock pi manifold ?
    By mat82284 in forum 1996 - 2004 Mustang GT
    Last Post: 03-01-2009, 06:13 AM
  4. max boost for stock head bolts/gaskets??
    By 69fb00GT in forum 1996 - 2004 Mustang GT
    Last Post: 05-16-2007, 04:19 PM
  5. Max Boost on Stock bottom end???
    By 96modgt in forum 1996 - 2004 Mustang GT
    Last Post: 02-09-2007, 08:54 AM
