Purchasing E85 in 55 gal drums question - Page 2
Results 16 to 30 of 30
    Senior Member Array imajeenyas's Avatar
    Apr 2010
    Fort Gibson, Ok 74434
    106
    Hmmmm.....
    Quote Originally Posted by Juiced46 View Post
    Helomech- what brand E85 are you running?
    I picked up the Renegade E85 from my supplier today. He was wrong. This stuff is Leaded. I cannot find any info on Renegades site about it though. My car was tuned on pump E85. I am wondering how the Race Fuel Leaded E85 will affect the tune?
    Here is the label
    Like previously mentioned leaded fuel will take out your sensors and plugs. Why would they even make a leaded E85? E85 can't be made to predetonate so why add another anti-knock additive like lead?
    Here is the label
    I'm not sure who actually manufactures it, but it's the same stuff that comes from the pump at most all of the stations in our region. I also buy E98 from them as well for about .45 cents more a gallon.
    the way it was explained to me was that all e85 isn't created equal and often the blends are different depending of the load of fuel which makes it half hazard to have a sharply tuned car.
    Senior Member Array Juiced46's Avatar
    Apr 2003
    North Haven CT
    4,454
    Quote Originally Posted by BruceH View Post
    No idea why they make it leaded. However a ton of companies are making it with lead. Must be a reason.....
    Quote Originally Posted by 97stsnake View Post
    Exactly what I have been hearing/reading. It can be cut with 87 octane or 93 octane. But how do you tell? You do not and put your motor at risk. Atleast buying it from the barrel I know its consistent. It may be more money but its still cheaper then race gas.
    Not to be off subject but how do you like the vmp tvs ?
  9. #22
    Apr 2003
    North Haven CT
    4,454
    So far its great. I just picked this car up and it was already installed. Going to retune it soon but the car feels strong. I have alot of experience with the other blowers like Mammoth 2.8, 3.4 Crusher etc. This blower is for sure worth it for a small 2.3 it does the job!
  10. #23
    Man I'm in the middle of my build but I'm up in the air I want the twins but in the back of my head the vmp tvs 2.3 or later 3.3 high compression and boost e85 would be nuts not including reliable I just could up boost at will like a wastegate and oh oh what if you threw a 125 shot to it and I've got a 5.4 billet bottom end
  11. #24
    Apr 2003
    North Haven CT
    4,454
    My old car was an Auto/Single 76mm Turbo Cobra. I really like the Auto/Turbo combo alot more. The TVS is still fun dont get me wrong. I would rather have a turbo though.
  12. #25
    I test all my fuel that I buy from the distributor. I also run an Ethanol content display in my car, so I know what the mix is at all times. If for some reason my batch tests low, I just add E98 to the mix until it tests correctly. Same goes for when my gauge reads low in the car, just add E98 until it's where I want it. I don't know of any distributors or manufacturers of Ethanol fuels in my area that use 93 octane to cut the fuel to E85, they all use 87 octane to adjust the rating, I think it would be a waste of money to use 93 to do it especially since the end result is the same. Even if I were to pay the incredibly inflated prices of the "Race" Ethanol, I would still test it to verify the mix.
  13. #26
    Apr 2003
    North Haven CT
    4,454
    Quote Originally Posted by Helomech74 View Post
    Can you post pics of your ethanol content gauge and how you have the sensor installed in the fuel line if possible? I am debating on doing this. Thinking of putting the display in the center console or glovebox.
  14. #27
    Are you getting your fuel in Bowlingreen ky? I live maybe 5 mins from valor oil which is renegade fuel. Im going to be buying 2 55 drums of E85 sucks it is leaded tho because that will kill sensors
  15. #28
    What do you think about an 11.1 compression twin turbo 00r engine running e85
  16. #29
    Also I can't remember where I saw it but someone makes an inline ethanol analyzer I wanna saw it was fast . That way I think you could probably setup timing and fuel charts according to the octane rating of the mixture.
  17. #30
    I use to get my e98 here and dilute shipping is $231 they unload it off the truck for you also. I make my own ethanol know super easy and cheap.
    http://www.maperformance.com/55-gall...cing-fuel.html
  1. 5 gal ice box for sale
    By 2Vfromhell in forum Power Adders
    Last Post: 03-28-2011, 11:45 PM
  2. 55 lb injector question
    By rossmacd in forum Tuning and Diagnostics
    Last Post: 07-23-2007, 09:46 PM
  3. Question about 3.55 vs 3.73 with 5 speed
    By 05Saleen1228 in forum 2005 - 2010 Mustang GT
    Last Post: 11-18-2006, 08:12 PM
  4. Purchasing a used Delta Chip. Question.
    By 1BAD281 in forum Tuning and Diagnostics
    Last Post: 01-03-2005, 08:59 AM
  5. Replies: 10
    Last Post: 10-01-2004, 06:13 PM
