Just wanted to say thanks - NGK FX wideband yellow to 9608 SCT cable red wire NGK AFX brown to SCT black and green
USE Analog 7 in the Live Link software - Use the (1.4*v)+9 formula The cable chart says use analog 2 - incorrect
SCT phone tech support was not helpful and even misleading
I know, an old post but this is the way the equation works.
You need to know what the NGK AFX wide band's min and max reading are. Then you can make the equation yourself.
Example 1, if minimum AXF gage A/F reads is "9". In the equation when the V(0 to 5volts)minimum=0. The constant in the equation is "9" and the SCT data will read A/F of 9.
Simply put, the constant is the minimum A/F the gage (9) will read because the V=0 at minimum.
Gage reads A/F 9:1. (0*1.4)+9=9 SCT reads 9
Example 2, if the maximum AXF reads is "16". In the equation when the V(0 to 5 volts) maximum=5. The multiplier in the equation is 1.4 and the SCT data will read A/F of 16.
The "multiplier" is then calculated from the maximum A/F the gage will read (16) because the V=5 at maximum. (16-9)/5=1.4 is the multiplier.
Gage reads A/F 16:1. (5*1.4)+9=16 SCT reads 16
Related Threads
1.8M posts
53.5K members
Since 2002
