Quickest Overall
1) BADASS03SVT............8.33 @ 163.xx w/ a 1.22 (L&M Teksid, Whipple 4.0, C4, SRA 8.8 w/ 3.55s, 3305#'s)
1) AJ………………………………..8.54 @ 164.95 w/ a 1.26 (Boss 5.0 block, HP TT 62mm, FB 4r70W, 28psi, Moser 9in. 3600#)
2) JRS Blown Snake.........8.72 @ 154.04 w/ a 1.25 (Blower only. 3.4 Whipple)
3) BADASS03SVT…………….8.78 @ 152.45 w/ a 1.25 (L&M Teksid, VMP 2.3 TVS, C4, SRA 8.8 w/ 3.73s, 3265#'s)
4) BLK_03............………...8.88 @ 157.xx w/ a 1.48 (HPP Twin 61mm, TH400, Kitchen Built Teksid)
5) FastMark....................8.95 @ 154.xx w/ a x.xx (Hellion 88mm)
6) Engcon......................9.11 @ xxx.xx w/ a x.xx (Kenne Bell 2.4L)
7) jmccoy04...................9.16 @ 152.xx w/ a 1.42 (SRA C-4 Precision 76 crossed the scales at 3300)
8) NV2L8ULUZ............….9.16 @ 148.79 w/ a 1.37 (Procharger F1C, SRA, Auto)
9) Dan...........................9.40 @ 149.xx w/ a x.xx (Kenne Bell 2.2L, .020 over Iron 04 cobra block , stock cobra crank , cp pistons , Pa c-4 , sra)
10) STUSWS6.................9.44 @ 145.8x w/ a 1.43 (3.4L whipple, Auto, SRA)
11) BADASS03SVT..........9.46 @ 140.xx w/ a 1.35 (Auto/SRA/Posi Port)
12) Kingkiller..................9.48 @ 153.xx w/ a 1.46 (KECS built teksid 4.6/Precision 76/4R75W/Solid 8.8/3195#'s)
13) SVTboy....................9.52 @ 145.xx w/ a x.xx (Hellion single, 76GTS)
14) Turbotrail93………………9.52 @ 143.xx w/ a 1.38 (281 CID, 2.8KB 25psi, 4R70W, SRA, 3450#'s)
15) LITTLEMAGS............9.53 @ 148.xx w/ a x.xx (F1a and 100 shot. teksid block/marauder heads/ 3.80 stroker and th400 with wrong converter still)
16) AJ...........................9.55 @ 143.75 w/ a 1.37 (KB 2.8 Mammoth, 26psi, Freddy Brown Auto, 9in. Rear)
17) Snakesvt04..............9.54 @ 144.32 w/ a 1.48 (2.8KB 3.20/6lb, SRA/Auto, 3.55, Slicks @ 3475 lbs)
18) NV2L8ULUZ……………..9.58 @ 142.87 w/ a x.xx (3.4L Whipple, SRA, Auto)
19) NV2L8ULUZ……………..9.65 @ 140.15 w/ a x.xx (2.3L Whipple, SRA, Auto)
20) rtusnake..................9.66 @ 142.42 w/ a 1.38 (3.4L, T-56, SRA)
21) 88LX50.........………...9.70 @ 148.02 w/ a 1.51 (6.32 @ 113.59 1/8th, 3.4L Whipple, 324 Boss Block, Stage III heads, 100shot)
22) Wolfpack Speed........9.76 @ 138.xx w/ a x.xx (KB 2.2 @ 21lbs, C4, 8.8)
Quickest Turbo
1) Shane97Cobra.............8.27 @ 167.22 w/ a 1.33 (Teksid 284ci, Speed Inc TT 67/66mm CEA, TH400, 30psi, SRA 8.8 w/ 3.27, 3400#)
2) AJ………………………………...8.54 @ 164.95 w/ a 1.26 (Boss 5.0 block, HP TT 62mm, FB 4r70W, 28psi, Moser 9in. 3600#)
3) BLK_03............…………..8.88 @ 157.xx w/ a 1.48 (HPP Twin 61mm, TH400, Kitchen Built Teksid)
4) FastMark...............…....8.95 @ 154.xx w/ a x.xx (Hellion 88mm)
5) WMD..........................9.12 @ 149.xx w/ a 1.39 (3250 LBS Twin 6266, Turbo 400)
6) jmccoy04....................9.16 @ 152.xx w/ a 1.42 (SRA C-4 Precision 76 crossed the scales at 3300)
7) Kingkiller.....................9.19 @ 154.xx w/ a 1.46 (KECS built teksid 4.6/Precision 76/4R75W/Solid 8.8/3170#'s)
8) SVTboy...............……....9.52 @ 145.xx w/ a x.xx (Hellion single, 76GTS)
9) LTZMach......................9.68 @ 149.xx w/ a x.xx (FatFab Twin 6466s, Stock T-56, SRA, Stock computer, Slicks, E85, 3580#)
Quickest Twin Screw/Nitrous
1) 88LX50.........………………..9.70 @ 148.02 w/ a 1.51 (6.32 @ 113.59 1/8th, 3.4L Whipple, 324 Boss Block, Stage III heads, 100shot)
2) Hissssnsvt.........…………..9.77 @ 143.12 w/ a 1.46 (3.4 Whipple 4.0/4lb w/ nitrous, 6 speed/SRA, 3.55 , Slicks @ 3500 lbs)
3) Ricksterman......…………..9.87 @ 138.1x w/ a 1.36 (DA 7154', 6-spd, 2.3 Whipple Gen II, 175 dry shot, SRA, 3420#'s)
4) 03SonicCobra......………...9.88 @ 142.85 w/ a 1.56 (KB 2.8H, N2O, 4R70W Auto, Stock IRS, Stock weight)
5) jeremiahhussey...………...9.95 @ 140.90 w/ a 1.50 (2.3 Whipple w/ nitrous, IRS, 6 speed, and slicks at 3750 lbs.)
Quickest Twin Screw / Roots only
1) BADASS03SVT.............8.33 @ 163.xx w/ a 1.22 (L&M Teksid, Whipple 4.0, C4, SRA 8.8 w/ 3.55s, 3305#'s)
2) WV_Snake..................8.71 @ 160.xx w/ a 1.2x (Stock motor, Whipple 4.0, C4, 9")
3) JRS Blown Snake.........8.72 @ 154.04 w/ a 1.25 (3.4 Whipple)
4) BADASS03SVT…….……….8.78 @ 152.45 w/ a 1.25 (L&M Teksid, VMP 2.3 TVS, C4, SRA 8.8, 3265#'s)
5) Engcon..................…...9.11 @ xxx.xx w/ a x.xx (Kenne Bell 2.4L)
6) Cliff............................9.2x @ 14x w/ a x.xx (???)
7) WMD…………………………….9.35 @ 144.xx w/ a 1.34 (283 CID, 3.4 Crusher, C4, SRA)
8) Dan.....................……..9.40 @ 149.xx w/ a x.xx (Kenne Bell 2.2L, .020 over Iron 04 cobra block , stock cobra crank , cp pistons , Pa c-4 , sra)
9) STUSWS6............……...9.44 @ 145.8x w/ a 1.43 (3.4L whipple, Auto, SRA)
10) Turbotrail93………………….9.52 @ 143.xx w/ a 1.38 (281 CID, 2.8KB 25psi, 4R70W, SRA, 3450#'s)
11) Snakesvt04.........……….9.54 @ 144.32 w/ a 1.48 (2.8KB 3.20/6lb, SRA/Auto, 3.55, Slicks @ 3475 lbs)
12) AJ........................…...9.55 @ 143.75 w/ a 1.37 (KB 2.8 Mammoth, 26psi, Freddy Brown Auto, 9in. Rear)
13) NV2L8ULUZ............…..9.58 @ 142.87 w/ a x.xx (3.4L Whipple, SRA, Auto)
14) NV2L8ULUZ...............9.65 @ 140.15 w/ a x.xx (2.3L Whipple, SRA, Auto)
15) rtusnake...................9.66 @ 142.42 w/ a 1.38 (3.4L, T-56, SRA)
16) Wolfpack Speed.........9.76 @ 138.xx w/ a x.xx (KB 2.2 @ 21lbs, C4, 8.8)
17) BurnTire…………………….9.97 @ 135.xx w/ a 1.38 (Whipple 2.3L 20PSI, TH-400, 8.8)
Quickest Twin Screw, IRS, 6-speed
1) Broke7..................9.73 @ 141.xx w/ a 1.45 (6spd, IRS KB 2.8H)
2) 88LX50.................9.81 @ 146.78 1.564 60ft...6.409 @ 113.35 1/8th (3.4L Whipple, 324 Boss Block, Stage III heads)
3) F8LBITE................9.94 @ 140.25 w/ 1.46 60' (2.8H KB 3.20/6lb, IRS, 6 speed, 3.55 gears, and slicks at 3755 lbs.)
4) G03SVT…………….....10.08 @ 137.89 w/ 1.47 (2.9 Whipple, T56/IRS, Stock Long Block, 3.73, Slicks @ 3810lbs)
5) Sharksfan81..........10.08 @ 139 w/ a 1.54 60ft 6.525 @ 109.63 1/8th (2.9L Whipple, Stock Long Block, IRS, Stock T56, full interior, E85, AED Tune)
6) Antex....................10.10 @ 140.09 w/1.41 (2.8H KB 3.50/6lb, 6 speed/IRS,3.73, Slicks @ 3680 lbs)
7) Snorman...............10.108 @ 140.85 w/ 1.596 60' (Whipple 3.4, 3.5/2#, heads/cams, stock T56, 100% stock suspension, 28" QTP's, 3832lbs)
8) rtusnake................10.12 @ 131 (KB 2.4L)
9) Hissssnsvt..............10.19 @ 137.67 w/ 1.49 (2.3Whple 3.0/6lb, 6 speed/IRS, 3.55 , Slicks @ 3700 lbs)
10) SmokenGRA03......10.27 @ 136mph (Whipple 21 psi, Stock IRS, Stock T56, 17's 335/35/17 Hoosiers)
11) G03SVT…………….....10.30 @ 135.59 w/ 1.46 (2.3 Whipple 2.75/2, t56/IRS, 3.73, Slicks @ 3810lbs)
12) jeremiahhussey.....10.33 @ 134mph w 1.48 60ft (2.3L Whipple
13) ExChiTownStRacr....10.42@135mph 1.55 60ft 2.2kb, 20lbs boost, pump gas, 26X11.50 et street
Quickest Eaton / Nitrous
1) BADASS03SVT..............9.46 @ 140.xx w/ a 1.35 (Auto/SRA/Posi Port)
2) NV2L8ULUZ..................9.83 @ 136.79 w/ a 1.37 (Auto/SRA)
3) Posi............................9.85 @ 140.xx w/ a 1.43 (Auto/Nitrous/Posi Port/Vert)
4) Clifford from Strictly.....10.01 @ 136.52 w/ a 1.4? (Auto/IRS)
5) 03flamedcobra.............10.02 @ 139.59 w/ a 1.45 (6spd/SRA)
6) JDM Engineering#1.......10.08 @ 136.?? w/ a 1.5? (Auto/IRS)
7) CobraStruck................10.09 @ 134.52 w/ a 1.43 (6spd/IRS)
8) VENOMOUS03COBRA.....10.30 @ 134.74 w/ a 1.51 (6spd/IRS)
9) Sprayed Daily..............10.30 @ 133.63 w/ a 1.38 (6spd/SRA)
10) JDM Engineering#2......10.38 @ 134.?? w/ a 1.5? (6spd/IRS) (No port!) (Vert!)
11) 04Sloobra.........…………10.47 @ 123.xx w/ a 1.42 (C4, SRA, unported Eaton)
Quickest Ported Eaton Only (Stolen from IronTerp)
1) BADASS03SVT.........….9.82 @ 135.xx w/ a 1.35 (Posi Port/Auto/SRA)
2) iBiTe03..................…..9.91 @ 138.76 w/ a 1.37 (Posi Port/6spd/SRA/Cams)
3) soap..........................10.28 @ 129.87 w/ 1.41 Posi port/TH400/SRA
4) F8LSNAKE..................10.34 @ 132.00 w/ a 1.49 (Steggy stg IV/6spd/SRA)
5) CobraStruck...............10.48 @ 132.93 w/ a 1.58 (6spd/IRS)
6) Posi..........................10.51 @ 128.36 w/ a 1.48 (Posi Port/Auto/ VERT!)
7) sonic03snake..............10.55 @ 130.35 w/ a 1.44 (Stieg IV/6spd/SRA)
8) Rice Eatr....................10.59 @ 126.74 w/ a 1.53 (6spd/SRA)
9) Soap.........................10.65 @ 130.80 w/ a 1.57 (6spd/SRA)
10) Stinkapuss................10.68 @ 130.62 w/ a 1.59 (6spd/IRS)
11) Shadow Grey 03……….10.76 @ 130.72 w/ a 1.66 (6spd/SRA/3700lbs)
12) 03flamedcobra..........10.78 @ 127.xx w/ a 1.48 (6spd/SRA)
Quickest Unported Eaton
1) JDM Engineering#2.......10.38 @ 134.xx w/ a 1.5? (6spd/IRS) (Nitrous) (Vert!)
2) 94-98Transam.........…..10.59 @ 125.00 w/ a 1.51 (6spd/IRS) (Nitrous)
3) Z-06 Killa....................10.66 @ 130.30 w/ a 1.60 (6spd/SRA) (Nitrous)
4) Almo..........................10.69 @ 128.59 w/ a 1.54 (6spd/SRA)
5) F8LBITE......................10.86 @ 126.20 w/ a 1.71 (6spd/IRS) (Nitrous)
6) Mofasta......................10.87 @ 127.25 w/ a 1.53 (6spd/SRA) (Nitrous)
7) VENOMOUS96..............10.84 @ 123.89 w/ a 1.50 (Auto/SRA)
8) 94-98Transam.............10.88 @ 125.50 w/ a 1.48 (6spd/IRS)
9) Ratt Fink...............…….10.92 @ 125.59 w/ a 1.51 (6spd/SRA)
10) 04yellowcobra............10.92 @ 126.23 w/ a 1.52 (6spd/SRA)
Quickest Stock boost/unported Eaton
1) Almo..................……...11.01 @ 126.51 w/ a 1.63 (6spd/SRA)
2) sonic03snake……………….11.16 @ 125.08 w/ a 1.50 (6spd/SRA)
3) BADASS03SVT………….….11.73 @ 119.xx w/ a 1.xx (6spd/SRA)
Quickest Turbo
