'13 GT500 just decided not to start.
Results 1 to 3 of 3
    Default '13 GT500 just decided not to start.
    I have a friend of mine who has a 2013 GT500 with full boltons + steeda triple pass heat exchanger with dual fans.
    His car is on base tune but he had the codes
    P0300
    P0303
    P0305
    Which basically was for the crank relearn process, he drove the car for 1 month with not alot of wots and drivability was just perfect, yesterday his car just suddenly decided to die without any CEL or any sound, After he popped the hood he noticed the air filter had fallen off but he is certainly sure it fell off hours before his engine decided to stop because he checked oil level that morning and everything seemd fine.
    The cars Fuel pump works fine, his oil is clean, plugs are clean but you do definatly feel the plugs are not igniting, We checked all the plugs n cops connections and no issues.
    What could cause this ?
    I also removed his supercharger belt to check the turning of the SC rotors and they are fine with zero issues.
    Tried removing battery, tried retuning, tried returning to stock. NOTHING.
    any tips or info is appreciated.
    does the car even turn over?
    If he has a sct x4, the crank relearn protocol is built in, under vehicle function. Follow it.
    Sent from my SM-G920V using Tapatalk
  1. Easy Cold Start, Hard warm start??
    By avexhype in forum 1996 - 2004 Mustang GT
    Last Post: 05-12-2011, 11:16 AM
  2. I have decided.
    By stangfreak in forum The Bar
    Last Post: 11-09-2009, 02:04 PM
  3. Decided to keep the cobra........
    By broke7 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-27-2008, 11:24 AM
  4. Decided 2 Stay With KB
    By Steel City in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-22-2006, 10:30 AM
  5. Its been decided.....
    By B00STDGT in forum 1996 - 2004 Mustang GT
    Last Post: 11-08-2005, 10:38 PM
