Cobra Engineering secondary timing tensioner fix - Page 2
Page 2 of 8 First 12345678 Last
Results 16 to 30 of 116
  1. #16
    Senior Member Array
    Feb 2007
    Vancouver Canada
    220
    When will these be available, I'll take one now.
  3. #17
    Senior Member Array JamesHell's Avatar
    Dec 2008
    da UP of Michigan, eh
    1,333
    Sorry guys I have been slacking today.
    Unfortunately I did the math and I will have to get $180 for this.
    Having to make it out of steel is what killed me. I had to get new tooling and it took 3 times longer to run than aluminum.
    Work is shutting down over Christmas and New Years. So I plan on running some of these off and making them available then.
    Thanks for your patience.
  4. #18
    Senior Member Array Tractionless's Avatar
    Aug 2007
    Atlantic Southeast
    1,928
    James,
    Any chance of an initial offering via group buy at a discounted rate via large volume @ once?
  6. #19
    Sure cheaper than $600 and some chains i dont need.
  7. #20
    Senior Member Array
    Jun 2010
    CA.
    238
    What's the difference from this and the one JM designed?
  8. #21
    Dec 2008
    1,333
    Quote Originally Posted by Tractionless View Post
    James,
    That would help. I am sure we could do something like that.
    Quote Originally Posted by SVTGabe View Post
    Honestly I don't know as I am not willing to buy one for $600 to look at. I developed this off of a stock Ford tensioner.
  9. #22
    Senior Member Array Swerve's Avatar
    Oct 2003
    5,037
    In a 2k hp 8k+ rpm application... John went on to say he felt there would be little if any noticeable gain on a typical 600hp 6500 rpm street type car.
    I'd love to see a true before & after test done.
  10. #23
    Senior Member Array BlownBlu97's Avatar
    Feb 2003
    Cortlandt manor
    5,412
    I would like one not for the MPH gain because that means ZERO to me but for the simple fact of keeping the cam timing correct! Put me on the LIST!
  11. #24
    Senior Member Array
    Feb 2007
    Vancouver Canada
    220
    If there is a group buy I am in.
  12. #25
    Senior Member Array cozmo2806's Avatar
    May 2008
    Mooresville, NC
    287
    In if there is a group buy also.
  13. #26
    Member Array
    Nov 2010
    Denmark (Europe)
    78
    Count me in for a group buy aswell
  14. #27
    Quote Originally Posted by BlownBlu97 View Post
    I think you are reading the tea leaves exactly correct, Joe. When Ford designed the passenger side tensioner they simply did it wrong! Someone looked at the driverside of the engine and saw the tensioner pushing downwards and he did the same for the passenger side (probably the same guy that 'engineered' the 4 thread sparkplug holes and the under cut radii on the crank snout among other little jewels). Therein lies the problem.
    The primary drive on the driverside exhaust cam tensions the upper chain track and leaves the lower side track slack. Chain manufacturers (and good old common sense) tell you to pick up chain slack on the slack (good name for it) side of the chain. That is exactly what the driverside tensioner does.
    On the passenger side, the primary drive is again on the exhaust cam but it is now left of the intake cam instead of right of the cam as it was on the driverside. When you position it to the left instead of the right of the intake cam, the tensioned side of the drive becomes the lower chain path and not the upper path as on the driverside. For reasons known only to Ford they chose to tension the same (and now incorrect) passenger side lower track of the secondary drive chain the same as they did on the driverside of the engine.
    When the chain tensioner extends the tensioning shoe, the effect with the OEM tensioner is to advance the intake cam on the passenger side by many degrees. How many? It depends on how much slack your particular drive chains provide. Take a moment and visualize the two cams with a taught chain on the driven side track. Now take the taught chain and push it up or down (our OEM tensioner pushes down). When you do this the exhaust cam does not move, it is held inplace by the primary drive chain.
    Instead, only the intake cam moves. The movement is in the direction of rotation, which means you are advancing the intake. How much? Again that depends on the available slack in your secondary drive chain. When most guys degree their cams they get super critical about getting the cam phasing correct to within a fraction of a crankshaft degree. That doesn't hurt anything - it also does not make a material difference in how the engine performs. if you get you cam phasing correct within a degree or so of your target number, whatever it may be, you are as good as you are ever going to get.
    The big question that should pop up now is, if all that is true why are we making such a big deal out of this admittedly wrong tensioner design. The answer is it moves the intake cam waaaay more than 1˚ and it is not static. The cam positioning is continually changing based on what the tensioner is doing. The other reason this is a big deal is the chain manufacturers are specific about the correct and incorrect way to tension the chain. The difference between right and wrong from the chain manufacturer's perspective is longevity. FWIW, Ford chose to do it exactly wrong on the passenger side of the engine.
    In the final analysis, we end up having two very good reasons to correct this oversight on the part of Ford Engineering. One is performance related and one is longevity related. Until James decided to make this product our options were few, far between and pricey. This is a huge step forward. I can not encourage you guys strongly enough to implement this upgrade. It is simply the right thing to do!
  15. #28
    Feb 2003
    Cortlandt manor
    5,412
    Perfect explanation Ed. As soon as it becomes available I'll be first on the list!!!!
  16. #29
    Oct 2003
    5,037
    If I were planning a motor build, this would be on the list of items to buy and install. I wouldn't drop the motor for the sole purpose of installing it though.
  17. #30
    Feb 2003
    Cortlandt manor
    5,412
    Im in the process of a complete motor build so it is perfect timing for me!!!
  18. Remove Advertisements
  1. Cobra Engineering Chain Tensioner Pivot Installation Fixture
    By eschaider in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-21-2018, 04:42 PM
  2. Secondary tensioner
    By redstanger in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-07-2013, 01:16 PM
  3. Secondary Tensioner Issue with Cams
    By torchred04 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-12-2011, 08:19 PM
  4. MMR billet secondary tensioner
    By pwrdbypsi in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-23-2010, 03:08 PM
  5. WTB: 4V secondary timing chain tensioner
    By Tabres in forum Engine Parts
    Last Post: 02-19-2010, 01:10 PM
