Cobra Engineering secondary timing tensioner fix - Page 3
Page 3 of 8 First 12345678 Last
Results 31 to 45 of 116
  1. #31
    Senior Member Array IWRBB's Avatar
    Jan 2003
    4,517
    So this is only for the passenger side head? I assume the stock piece is not a known problem child and leaving it on the drivers side is fine?
  3. #32
    Quote Originally Posted by IWRBB View Post
    The driverside tensioner functions both well and properly Eric. The only bad boy was the passenger side.
  4. #33
    Most engine builds sit around the $4000-$10000 or higher yet. A $180 is a no brainer...do it right the first time.
  6. #34
    Senior Member Array BlownBlu97's Avatar
    Feb 2003
    Cortlandt manor
    5,419
    Hope we can place our orders soon.
  7. #35
    I would like to order one as well..
  8. #36
    Give James a little elbow room guys. That first item was what is called a proof of concept. It show the dimensions, plumbing and concept were on target. The next step is to build the tooling to produce these little gems more than one at a time. That takes additional time, costs money and results in a lower cost for you, which in addition to the fix is something you all hold near and dear to your hearts (and wallets).
    This item is not going away any time soon and James will be more than happy to turn the production machine on for you - just give him a little more time to screw the whole thing together.
  9. #37
    Feb 2003
    Cortlandt manor
    5,419
    I have plenty of time, I'm no where ready for it.
  10. #38
    Will work on the gt500 heads also, or is it a 03-04 cobra deal only... Sorry if that is a dumb question
  11. #39
    Senior Member Array Tractionless's Avatar
    Aug 2007
    Atlantic Southeast
    1,928
    So bad head chain on passenger side and hot #7 & #8 holes on the drivers side. They're both bad
    Quote Originally Posted by BlownBlu97 View Post
    I'm with you, collecting parts for that inevitable day. Would love the group buy for these to go with my pivot studs, Melling pump, and (off topic) RXT collecting dust. Think the next buy is valve springs and James' IC manifold.
  12. #40
    Quote Originally Posted by Tractionless View Post
    So bad head chain on passenger side and hot #7 & #8 holes on the drivers side. They're both bad :big wink:...
    Yup! For different reasons but you're right, Keith they are both bad boys.
    It is amazing how many little design faux pas Ford engineering has left for us to 'discover' ...
  13. #41
    Moderator Array BADASS03SVT's Avatar
    Dec 2003
    Boston
    8,802
    can this be done when motor is already built / running?
  14. #42
    Senior Member Array Swerve's Avatar
    Oct 2003
    5,038
    Quote Originally Posted by BADASS03SVT View Post
    Valve covers and front cover must be removed. Then you lock the cams and remove the passenger side timing chains. Swap tensioners and put it all back together.
    When all that drama about the cloyes secondary chains came to surface on this forum I dropped my motor, trans, & K member and put the stock timing chains on over the course of a weekend. I set the degree wheel up and spun it around just to check & ensure the cams didn't go anywhere. They didn't...
  15. #43
    Dec 2003
    Boston
    8,802
    Quote Originally Posted by Swervedriver View Post
    ugh…was thinking it could be done with just the vc removed...
  16. #44
    Oct 2003
    5,038
    I seriously doubt it. I was hoping the same thing when I went in to replace the secondary chains. There wasn't enough space to even remove the primary sprocket from the end of the cam.
    Even if you could get the sprocket off somehow, you'd be up against trying to lock the guide tensioner somehow while simultaneously holding the chain up so it doesn't go slack on the crank sprocket resulting in it going together a tooth (or more) off...
    After goofing with it for about 15 minutes I said "no flipn way" and just took everything apart.
  17. #45
    Feb 2003
    Cortlandt manor
    5,419
    Man am I glad I discovered this now while it is torn all the way down. finally in the right place at the right time for once!!!!
  18. Remove Advertisements
  1. Cobra Engineering Chain Tensioner Pivot Installation Fixture
    By eschaider in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-21-2018, 03:42 PM
  2. Secondary tensioner
    By redstanger in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-07-2013, 12:16 PM
  3. Secondary Tensioner Issue with Cams
    By torchred04 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-12-2011, 07:19 PM
  4. MMR billet secondary tensioner
    By pwrdbypsi in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-23-2010, 02:08 PM
  5. WTB: 4V secondary timing chain tensioner
    By Tabres in forum Engine Parts
    Last Post: 02-19-2010, 12:10 PM
