Few questions before install. With my set up...
Amazon stage 2 intake (95mm mass air)
Amazon diablo chip
magnaflow catted X
magnaflow catback
SFP 2.80 pulley
gatorbelt
SPF 100mm idilers, metco
TR6 plugs 40 gapped(?), some say 35
STOCK TB remember
What numbers should I see on the dyno?
What numbers and speeds should I expect at the track?
Also, what do you have your plugs set at 35 or 40?
What boost are you guys seeing?
Again, 2.80 pulley guys respond because I would like to have evidence from experience not what people have heard. Thanks a lot guys, I really appreciate it.
(also posted on svtperformance)
We have dynoed 480, with that combo. the car should run in the 11.4-11.6 range . Some cars have run 11.0s with that combo.
nitro all cars will differ. hope this helps
Senior Member
Right there with Pete look for 460-500 hp and with the program you have and some practice, dr's you can run mid 11's with the car. We have had a couple over 500hp with 2.80 pulley/chip/cai/exhaust w/ no headers but it was barely over 500.
good luck with your combo and keep us posted
Rick
Discussion Starter · #4 · (Edited)
When I get back home, I will send the chip back to you Rick. Be Ready for a good tune around 11.9 a/f to be SAFE!
also what boost will I see and do I set the TR6 plugs to .035 or 40? SFP said .040 and I think you said .035 Rick. Which one? Thanks again and I will be contacting you soon.:D
