I understand that a 98 gt has a 2 spd cooling fan. Is it possible that as the engine temp rises above the temp that is supposed to change the fan from low speed to high speed operation that the fan would stop instead of making the transition? That appears to be what is happening as I can see the fan turn on as the engine warms up but, after a bit the fans stop and the vehicle overheats. What could be the possible cause. Also, what is the difference between fan high speed ect 1 "on" and fan high speed ect 2 "on"? The turn on and off points are the same at 208 and 200 degrees? Thanks.
