1 - 8 of 8 Posts
I have just pulled the 225,000 mile engine out of my 90 coupe and purchased a 2001 cobra drivetrain computer and all the wiring harness to swap into the 90 model. I really need some help with the electronics of it all. I hope someone knows more about it than I do. All help and input is much appreciated.
I have diagrams and experience to help when you get stuck. Just contact me when you reach the point of need...........
hi im new to this website but saw that you had a diagram or knew how to wire up a modular motor in a foxbody? think you could help me out?
It will make the swap much easier if you get the entire wire harness for the front of the car including the dash harness. We did a 96 GT to 01 Cobra motor swap and the 01 harness made it an easy swap.
You need a helper to remove the dash to replace the harness; get a book or Ford Service dvd from eBay to show you how things go together.
I would also like some help. what i have is a 03/04 cobra body harness all the harness from an 03/04 cobra except the engine harness is an 01 cobra. I am putting an 01 cobra motor into my 93 gt and not sure how to go forward. do i need a 01 computer or 03/04 computer and will the 01 engine harness plug in and work without rewirng anything. thanks
You need the 01 computer. As for the connectors plugging in w/o and reqiring...you have both ends, take a look. If you got the Ford service DVD it would show you the functions and wires of both years with each connector.
1 - 8 of 8 Posts
