Results 1 to 11 of 11
01-14-2014, 01:32 PM #1
- Join Date
- Apr 2005
- Posts
- 67
Heavily Modified, can I put any supercharger I want on my car?
https://www.youtube.com/watch?v=QVUHzAbkbew
This is my 2001 SVT Cobra. This is a video of the car idling after getting a tune from bob kurgan. It put down 343RWHP / 329RWTQ naturally aspirated.
284ci built by Modular Performance
Custom Diamond Pistons
Oliver Billet Rods
BULLET Custom Cams
Livernois Stage 3 CNC Ported Heads
ProMotion built 5-speed transmission (750hp)
I had it built with custom ground turbo cams, but now I don't have the funds and dont really want to go that far and turbo it, so I was thinking of getting a used supercharger and somehow making it fit... the engine is built as **** and is just nasty so I can just put high boost and get like 700hp on pump im sure ? anyways... I just want to supercharge it so bad and really only have like a 3K spending limit, less is even better. On ebay I see this .. http://www.ebay.com/itm/2003-2004-Mu...abe504&vxp=mtr
LOL is there any way to mount that on the engine, and how much power should I expect with that if I ran it as hard as I could. Or could I get a used 2.3L whipple or 2.9L whipple and somehow get some performance shop to make the brackets and whatnot to make it fit? I am sick of driving around a car thats meant to be boosted but with no boost and only ~350hp so if I can put an eaton and get 600 hell I would do it for the time being, the eaton is only 800 bucks too!! maybe I could port and polish and with the built motor get like 700hp with the eaton or am I just dreaming. I have been out of the car world for 5 years and JUST got back and got the car in the shop getting back running again so now is the time to do it. If i could get a turbo kit cheap I would, but I hear on3 performance has all sorts of problems, and I just love superchargers, especially whipples.
TLDR: Can I basically buy ANY whipple and have someone custom fab it to fit my built motor and then get a tune and just rock out? -
Sponsored Links Remove Advertisements
01-14-2014, 01:43 PM #2
- Join Date
- Apr 2005
- Posts
- 67
what if i got an eaton and then intercooled it, and put the highest boost i could? would that work?
01-14-2014, 09:59 PM #3
Sure...John built ya a hell of a motor...u can pretty much do what u want...there are even used procharger kit floating around for 2k...
01-15-2014, 01:45 AM #4
- Join Date
- Apr 2005
- Posts
- 67
i g
would having :turbo cams: affect it negatively in any way or if I supercharged this with a 2.9L whipple what do you think it could make
01-15-2014, 03:07 AM #5
- Join Date
- Apr 2005
- Posts
- 67
ok I found this, does this look "safe" to you? http://www.ebay.com/itm/O3P-4-6-Must...ccc623&vxp=mtr or could it be a scam is there any way to protect myself
01-15-2014, 03:31 AM #6
- Join Date
- Apr 2005
- Posts
- 67
I will be going with a 0n3 performance single turbo kit and I will just replace the crappy parts with quality ones, (what is the best turbo I can get and what do you recommend? Its just a street car that hauls ass I never go to the track. Only using 93 octane. 76mm ? what AR
01-15-2014, 12:23 PM #7
In my opinion, putting an On3 performance turbo kit on your 2001 Cobra would be a mistake. In general, turbo kits present reliability issues and the low cost On 3 kit has proven to be problematic with exhaust leaks and other problems. Another minus of the On3 kit is that the factory K member must be replaced with a weaker light weight drag race tubular unit.
If you want to add boost on a budget without the reliability issues and headaches of a turbo kit, I would piece together a used Vortech, Paxton or pro charger blower kit. The street/strip blowers such as the Vortech T, Paxton Novi 2000 and the Procharger F units can outrun turbo kits if they are spun hard enough so why put with the turbo kit head aches? especially with a street car?
As an example of a low cost way to add boost, I put togeather an aftercooled Vortech kit with a T trim head unit with 60 pound injectors, Lightning MAF,Vortech maxflow bypass valve, home made power pipe, Diablosport MAFIA, Terminator tank and pumps, AEM methonal kit for just over 3 grand. not too bad. No need to swap out the factory K member either. Except for a leaking pulley shaft seal that I had to replace shortly after installing the used Vortech head unit, the kit has been reliable.
Here is my used kit installed on my 2001 Cobra
I'm perfectly satisfied with this kit and when I get around to rebuilding the short block, I will add an overdrive crank damper, 8 rib conversion and a upgraded tensioner to get the big boost levels that the T trim unit is capable of. -
01-15-2014, 03:09 PM #8
I would do the CG Fabrications system. I use a Precision PT8285 and it spools quite nice actually.
01-15-2014, 04:57 PM #9
Blown cars can run real good with a head unit capable of putting out good amount of boost. An example: 29 pounds of boost out of a T-Trim Vortech results in 7.99 170 MPH without the complexities of a turbo set up.
Read more: http://www.mustang50magazine.com/fea...#ixzz2qVSGt874 -
01-16-2014, 02:36 PM #10
- Join Date
- Apr 2005
- Posts
- 67
hmm im really liking the sound of the centri blowers...... thanks for the info guys.... is there a certain model or 'size' I should go for where I can make optimal power/boost for 93 octane? thanks a ton
01-16-2014, 06:14 PM #11
For Sale FS:Highly Modified Vortech V2-Si Supercharger System
By yellowS281 in forum Power AddersReplies: 2Last Post: 12-02-2013, 10:35 AM -
By yellowS281 in forum 1996-2004 Mustang ClassifiedsReplies: 0Last Post: 06-13-2012, 07:50 PM -
1996 Mystic Cobra, heavily modified.
By gpowrie in forum VehiclesReplies: 0Last Post: 07-02-2010, 11:10 AM -
Heavily Modified Mustang Stolen out of my garage!
By 2k1 6t8 in forum SoutheastReplies: 24Last Post: 05-30-2007, 05:21 PM -
Whats considered heavily modified?
By cpu77 in forum 2003 - 2004 SVT Mustang CobraReplies: 12Last Post: 10-29-2006, 12:35 PM
Best Black Friday Automotive &...
