I have the internals from a running 2005 3v mustang with 110k on it. I bought the engine for the block and do not need the internals. Block was pulled to make way for a custom built crate motor. The oil was changed every 5k miles with either amsoil or mobil 1 full syn. There was still crosshatch in the bores! I can send you photos of all main and rod bearings to show you how good of condition these parts are in. No scoring anywhere. Message me for any pictures you want!
MAKE AN OFFER WILL SELL EVERYTHING SEPARATE OR AS A GROUP!
4.6 6 bolt stock crank - pristine journals with no scoring. I am told the cranks from the 2005+ 3v mustangs will hold about 700hp. But you should do your own research.
Set of 8 pistons and rods. All of these are in great conditions. 1 of 8 pistons has 3 VERY small marks on the top a tad larger than the size of a push pin. Will gladly send photos!
3v Oil pick up with bolts
4.6 rear main seal housing with bolts
All of the main caps 4 bolt main w/ 2 side bolts
