Handy Kenne Bell Octane Calculator - Page 2
Page 2 of 2 First 12
Results 16 to 27 of 27
  1. #16
    Kenne Bell Superchargers Array KC@KB's Avatar
    Nov 2003
    874
    Default Re: Handy Kenne Bell Octane Calculator
    Quote Originally Posted by bcstrong View Post
    regarding the post about how much octane to add per lb. of boost over stock is there also a a safe amount of boost to add for every point dropped in compression. For example how much could i turn up the boost if the kit is designed for an engine with 9.85:1 compression (96 cobra) and i have had my bottom end built to 8.5:1 ?
    Every point in CR is equivalent to about 1.54 psi boost, or every psi = .65 CR, so 9.85-8.5 = 1.35 CR drop, and 1.35/.65 = 2.08 psi more you could run.
    Hope this helps!
    Regards,
    Ken
  3. #17
    Hello there, I do not have Excel, so I can't use this calcuator. Can someone please help me and calculate what 5 gallons of 93 octane with 4 gallons of 110 octane would be?
  4. #18
    it wont open for me either ?
    this nos octane booster i read about the in instructions ,,say if ?i put in the tank down to a 1/4 tank but the high boost nos octane boost in it the fill top it off with 92 octane what would it be .?
    could i run safely with 03 cobra bottom end with stock lower pulley and a 3.25 upper .. ... i think thats 20 psi of psi of boost .? not sure?
    i got not problem buying the octane boost buy the case for every fill up. when i get down to say 1/4 tank ? or should i do it , at 1/2 tank .. please help.? mr bell. im going to get jms set tune it for me there 180 miles away roughly 1 way ., thanks for telling me about them ..
  6. #19
    Senior Member Array FEARSNO1's Avatar
    Jul 2003
    LA
    440
    won't open for me either
  7. #20
    Nov 2003
    874
    Quote Originally Posted by FEARSNO1 View Post
    Part of the problem is we had to zip the file up because modularfords.com would not let us attach an *.xls file before. Try it now that we were able to upload an *.xls file as an attachment.
    Regards,
    Ken
    Attached Files Attached Files
  8. #21
    Senior Member Array Pure03Venom's Avatar
    Apr 2006
    Baton Rouge
    457
    Quote Originally Posted by [email protected] View Post
    Regards,
    Ken
    And if anyone can't open excel for whatever reason, here it is in a hand quick and dirty web page...or for anyone that might want to embed it into their pages.
    Just remove the .txt extension.
  9. #22
    Member Array Abell's Avatar
    Jul 2007
    Brownsville, Tx
    74
    Regards,
    Ken
    This works great now!!!
    Thanks Ken!!!
  10. #23
    Boost-aholic Array JrSVT's Avatar
    Apr 2006
    LaFargeville, NY
    2,821
    Quote Originally Posted by GODSPEED11 View Post
    I think the formula used for this calculator was, for example:
    1st octane = 91
    2nd octane = 110
    gallons of 1st octane = 9
    gallons of 2nd octane = 4
    If you take 91 x 9 you get 819,
    then multiply 110 x 4 and get 440
    add the two sums together and get 1259
    then divide by total gallons...in this case 13 and you get the mixed octane rating of 96.84615
    I tried a few different octane numbers and my way of calculating and it came up the same everytime.
    hope that helps people out that can't D/L the file.
    Jr.
  11. #24
    Here is a related question to octane. There is a Fastlane gas station which sells "Trick" 100 octane at the pump near me ($7.49 /galon .... grumble grumble.....). I have filled up there several times, and I suspect the gas may be sour, because frankly my car seems to run better (smmother more power) on 91 octane. Is there an easy way to verify whether or not the gas is sour?
    Belinda
    2006 Mustang GT, 4.6 3V, KB 2.6L Stage 2, KB 91 octane tune
  12. #25
    svtoa-nashville Array mmustangsrus's Avatar
    Apr 2006
    nashville,tn
    1,245
  13. #26
    Default How does increasing octane hurt
    How does mixing fuels to increase octane hurt the engine. Just Curious.
  14. #27
    Kenne Bell Superchargers Array MIKE@KB's Avatar
    Nov 2007
    Kenne bell Superchargers
    647
    The mix can be off, on you are counting on it to right. The mixed fuel can also separate after sitting throwing off the ratios. its best to run a factory blend fuel for the octane you need or are tuned for.
  15. Remove Advertisements
  1. kenne bell and octane ?
    By 04kbstang in forum 1996 - 2004 Mustang GT
    Last Post: 03-22-2009, 05:32 PM
  2. kenne bell and octane ?
    Last Post: 03-22-2009, 02:36 PM
  3. Kenne Bell Octane Calculator HELP
    By GODSPEED11 in forum Kenne Bell Tech
    Last Post: 08-16-2007, 03:38 PM
  4. Kenne Bell 18-19lbs, 93 octane? timming? Help?
    By GreekSVT03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-28-2005, 04:57 AM
  5. kenne bell worth getting if solely on 91 octane?
    By doubleblack in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-20-2003, 12:01 PM
