New Product!!! Dont let this part destroy your GT500 engine!! The problem and the fix >>>>
Results 1 to 6 of 6
    Supporting Vendor Array Mod Mustang Racing's Avatar
    Jul 2004
    Camarillo, CA
    1,060
    Default Dont let this part destroy your GT500 engine!! The problem and the fix >>>>
    MMR has had a overwhelming # of calls from engine builders and customers across the country with broken/failed lower crankshaft sprockets. It seems the majority have been those with upgraded camshafts but many have also been stock applications. We even received a call from a MMR dealers who had even broke 2 on the same engine. When this part breaks catastrophic failure is certain (bent valves, damaged pistons,cylinder heads etc). MMR went to work quickly on a solution and are now selling the MMR Billet Steel gear. This gear replaces the factory powdered metal gear directly with no other changes, the MMR gears are manufactured from billet 9310 heat treated material and precision made in the US by MMR. If you are building aftermarket engine, rebuilding a engine you need one of these!!! Retail on the Billet steel gears is $299. Order here:
    http://www.modularmotorsportsracing....roducts_id=414
    Dont let this happen to you:
    The new MMR Billet gear
    Jul 2004
    Camarillo, CA
    1,060
    bump ttt
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
    Jul 2004
    Camarillo, CA
    1,060
    bump ttt
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
  1. Fuel problem? Air issue? I dont know.
    By lightemup in forum 1996 - 2004 Mustang GT
    Last Post: 10-13-2010, 04:15 PM
  2. A simple fix to a big handling problem
    By Granatelli in forum Vendor Deals
    Last Post: 07-28-2010, 05:29 PM
  3. Squeling problem figured out. Help fix?
    By darkside03gt in forum 1996 - 2004 Mustang GT
    Last Post: 05-25-2010, 04:32 AM
  4. Here Are Part #s for TKO500/600 Fix
    By 4.6LPoppy in forum 1996 - 2004 Mustang GT
    Last Post: 01-04-2009, 04:50 PM
  5. body reapir? need new part or fix it
    By mustang-belle1 in forum Auto Body Repair
    Last Post: 11-17-2006, 11:06 PM
