Pics of my -16 head fittings and -20 rad supply
Results 1 to 13 of 13
    Default Pics of my -16 head fittings and -20 rad supply
    I tackled this because I didn't feel the -12 sold in other kits was sufficient in my mind to flow enought coolant to make me happy. This is two -16 head coolant fittings I made supplying the piece mounted to core support that houses fill point and inline t stat. -20 comes out of that supplying radiator with a custom -20 an fitting I made.
    Looks very clean!
    Demented and old Array showme cobra's Avatar
    Dec 2005
    wentzville mo
    5,322
    Very nice-is your car a daily or track only?
  6. #4
    Quote Originally Posted by eutynem View Post
    Looks very clean!
    Thanks!
    Quote Originally Posted by showme cobra View Post
    Definitely a full streetcar ac,heat,everything. My last fox a was a racecar and I wanted to build something pretty quick that I could drive anywhere without worries.
  7. #5
    Senior Member Array BlownBlu97's Avatar
    Feb 2003
    Cortlandt manor
    5,420
    Looks awesome! Great work!
  8. #6
    Dec 2005
    wentzville mo
    5,322
    I can see why you would go with the 16an fittings-i have a delete kit with 12an but my car is track only
  9. #7
    In your application totally understandable then.
  10. #8
    Senior Member Array
    Jan 2014
    Barnhart, MO
    231
    Build me this... Lol. Looks really good.
  11. #9
    Senior Member Array oxford03cobra's Avatar
    Jun 2007
    Greenville TX
    155
    Nice setup
  12. #10
    Very nice work Cody! You definitely did the right thing with the -16 hose out of the heads. The -20 after the merge helps maintain the flow nicely. Although it is hard to sometimes find and pricey a -24 line after the merge would approximate the OEM top hose ID fairly closely.
    The visual when you look at the engine compartment is just stunning. Very. very nice work Cody!
  13. #11
    Thanks Ed! Those compliments mean a lot coming from you!
    On the subject of the -20 merge. The reason I was able to justify it so easily was in the stock crossover it necked down severely smaller if you looked into the outlet itself. So I made an effort to make it free flowing as possible to prevent any choke points I could. I would venture to say this flows as good or better than the stock crossover that I had.
    -Cody
  14. #12
    Funny thing is even with all of that. The water passage in the thermostat even if its a high flow thermostat is only the size of a single -20 fitting.
  15. #13
    Looks very nice!
    Can you share a list of your parts?
  16. Remove Advertisements
  1. Carbon Fiber Rad Support teaser pics
    By Tucker in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-07-2009, 12:47 PM
  2. Carbon Fiber Rad Support teaser pics
    By Tucker in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 05-30-2009, 08:50 PM
  3. Carbon Fiber Rad Support teaser pics
    By Tucker in forum 1999 - 2001 SVT Mustang Cobra
    Last Post: 04-21-2009, 04:05 PM
  4. Anyone have pics of the MAC SS Rad Cover installed?
    By Duke4 in forum 2005 - 2010 Mustang GT
    Last Post: 05-26-2006, 09:02 PM
  5. Custom Rad cover, Pics inside
    By [email protected] in forum 1999 - 2004 SVT Lightning and 2001 - 2003 Harley Davidson F150
    Last Post: 03-09-2004, 07:40 PM
