Logging Boost
Results 1 to 3 of 3
Thread: Logging Boost
    Senior Member Array Killspray_01's Avatar
    Feb 2007
    DFW
    171
    Default Logging Boost
    Iíve finally decided to take the plunge into self-tuning and data-logging, via SCT, and I have lots to learn. Iím definitely a newb in this area.
    In regard to logging boost, is there a way to utilize my eBoost 2 wiring as it already has a vacuum/boost source from my intake or do I need to install a GM MAP sensor?
    Please note that I have a 2001 Mustang and my car did not come stock with a MAP sensor.
    Thanks.
    Steve
    Senior Member Array boosted01's Avatar
    Jun 2007
    North Carolina
    304
    On my 01 GT I just used a 3 bar map sensor and ran a good vacuum source to it. Then wire the MAP sensor into the aanalog side of the XCAL. You can then find the calibration equations in the SCT software and tweak it if nececessary. I used a mighty vac hand pump to accurately dial in my map sensor equation. Im also using the eboost 2........... but thought this would be much more accurate.
    Feb 2007
    DFW
    171
    Thanks bud
  1. AF logging
    By rick_sudac in forum 2011 - 2014 Mustang GT and Boss 302
    Last Post: 10-16-2011, 03:16 PM
  2. Logging boost - how?
    By FordEvangelist in forum 2005 - 2010 Mustang GT
    Last Post: 07-20-2010, 01:22 AM
  3. Logging Boost
    By [email protected] REMOVED in forum Turbo Modular
    Last Post: 12-13-2009, 01:57 PM
  4. Data logging boost.
    By NeverEnuff in forum Tuning and Diagnostics
    Last Post: 07-08-2008, 07:24 PM
  5. Logging Boost????
    By ITSTOCK in forum Tuning and Diagnostics
    Last Post: 09-06-2004, 07:19 PM
Tags for this Thread
