03-04 Cobra Eaton gaskets & bolts?
Results 1 to 7 of 7
    Senior Member Array
    Nov 2005
    Bucks County, PA
    1,397
    Default 03-04 Cobra Eaton gaskets & bolts?
    Hey what's up fellas, anyone aware of any vendor selling a complete or close to complete 'kit' of 03-04 Cobra Eaton gaskets & bolts?
    I need to pull the Eaton blower and I wanted to put new hardware on there. Any leads would be great. Thanks
    Also, is the PCV valve locator under the lower intake the same as the one in the rear of our driver side head, PCV grommet opening?
    Senior Member Array soap's Avatar
    Feb 2003
    MI
    2,932
    There are no gaskets on the blower itself, just use RTV if you remove the rotor pack. As for the bolts....just remove one and go to your local hardware store to match them up. I did that when I swapped the OEM bolts for some polished stainless hex head bolts.
    Love
    PCV under the blower is totally different, its a threaded steel fitting.
    --Joe
    Seems like I saw a 'complete' kit somewhere recently. Check Tousley Ford, and Livernois Ford. I ended up buy it all peice-meal, because I did not want to use new TTY bolts, that would have to be replaced again.
    I am a little surprised ARP does not offer a kit for this. Maybe try calling them. I bought all my SS hardware from Ace Hardware, and it was more expensive than was expecting buying the bolts 1 at a time.
    I think it I was doing it again, I would get all the bolt sizes handy and call ARP to see if they could pull it all together.
  6. #4
    Senior Member Array
    Nov 2005
    Bucks County, PA
    1,397
    Thanks for the replies fellas.
    Have been using the FordParts.com website to locate what I need but couldn't distinguish from their pics of there was a gasket needed. Their bolts pricing is of course absurd. But I will look further into both of your suggestions. Much appreciated guys.
  7. #5
    Senior Member Array
    Nov 2005
    Bucks County, PA
    1,397
    Quote Originally Posted by soap View Post
    --Joe
    Joel do you think its necessary at all to replace that threaded PCV? Or just maybe just consider replacing the vacuum line that connects to it? I ask only because I can’t find that anywhere on the diagrams available through Fordparts.com. I just want to make sure I take care of everything while the blower is off. Don’t to miss anything while its off. Thanks again for all your help. Doing it for the first time myself and just hoping none of the bolts break off when I try removing them.
  8. #6
    Senior Member Array JamesHell's Avatar
    Dec 2008
    da UP of Michigan, eh
    1,334
    Here is a good alternative for the blower hold down bolts - Click Here
    You get more than you need, but Im sure its still cheaper.
    Then just call Steve at Tasca and he will hook you up with all the gaskets.
  9. #7
    Senior Member Array
    Nov 2005
    Bucks County, PA
    1,397
    Quote Originally Posted by JamesHell View Post
    THANK YOU jAMES! THATS BADASS RIGHT THERE. i APPRECIATE IT BUDDY!
  10. Remove Advertisements
  1. Wtb New Head Gaskets And Bolts
    By KENNYS96T in forum Engine Parts
    Last Post: 04-22-2010, 06:32 AM
  2. 4.6L 2v Head gaskets and bolts + spacers
    By TurboZinc in forum Engine Parts
    Last Post: 01-25-2009, 05:48 PM
  3. FS: (2) IAC Valves w/ gaskets and bolts
    By hbk_136 in forum Engine Parts
    Last Post: 10-08-2008, 04:44 PM
  4. Head bolts and gaskets
    By scjfox in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-04-2006, 10:47 AM
  5. Do I need gaskets/bolts with ported blower?
    By S/CCObra03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-30-2005, 07:46 AM
