5.4 SOHC/Lightning/F150/Expedition MMR Race Spec Chain Guides PN#542295
Constructed of Billet Aluminum vs the stock weak plastic, eliminates timing variation under high RPM and load. Reduces 2-3 degrees of forward/aft movement at the pivot. Works with all other factory and aftermarket components. Lifetime warranty against breakage. Red Anodized for wear and corrosion resistance. No more broken guides on performance applications!! Recommended for all 6000+ RPM applications Fits all 5.4 blocks (iron and alloy). Shown with wear guides but factory wear guides can be used to save $$
$199.99 (without wear guides)
$259.99 (with wear guides)
Order here: http://modularmustangracing.com.tempwebsite.net/cartgenie/prodInfo.asp?pid=873&cid=1
