help removing whipple 3.4 inlet.
Results 1 to 3 of 3
    Junior Member Array
    May 2015
    s.a texas
    16
    Default help removing whipple 3.4 inlet.
    I'm trying to remove the whipple inlet on my gen2 3.4 from my cobra. I already removed the 6 bolts that go into the case but won't even move. I already did try to hit it with a mallet but no luck. Is the the boost bypass holding it together or do you think it's just the silicone??
    Junior Member Array
    May 2015
    s.a texas
    16
    Well after some digging around I found out you have to remove the plate under the blower to remove the boost bypass port then the inlet comes right off with the help of some taps with a malet.
    Senior Member Array torchred04's Avatar
    Nov 2004
    Calgary Canada
    5,237
    You should just be able to pry it up off the o-rings on the boost bypass once the bolts are removed. use a couple small pry bars and just wiggle it slowly up from side to side it should come. I have done mine 2-3 times. Also a 6mm ball end allen key socket in 1/4" drive makes a world of difference getting those bolts on and off.
  1. removing whipple?
    By raym5_0 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-04-2012, 03:41 PM
  2. Help removing Crusher inlet?
    By 4sdvenom in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-10-2010, 05:11 PM
  3. Need advice for Removing 2.2L rear inlet
    By Pure03Venom in forum Kenne Bell Tech
    Last Post: 02-19-2009, 04:44 PM
  4. Removing Whipple Inlet?
    By yellow03cobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-19-2008, 04:12 PM
  5. New inlet for the Whipple 3.4
    By SVTBlaine in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-11-2007, 07:53 PM
