DOHC minus one
Page 1 of 3 123 Last
Results 1 to 15 of 31
Thread: DOHC minus one
    Default DOHC minus one
    I haven't been here for quite a while but I thought this may inspire some discussion.
    I went to move the '93 when it made an awful sound for a couple of seconds and stuttered and died.
    Autopsy photos...
    Big cam 1.
    Sprocket and chain 0.
    Finally got around to getting it tore down. This just keeps getting better...
    Junior Member Array
    Oct 2015
    New York
    11
    Ouch, can the piston be saved?
  6. #4
    I doubt it. I just hope the cylinders are OK.
  7. #5
    Junior Member Array
    Oct 2015
    New York
    11
    Best of luck with the repair
  8. #6
    Block, crank and rods are all good. New Diamond flat top pistons, rings and bearings will be on the way.
    Heads will be sent to Fox Lake. I expect some new valves and possibly valve guides will be involved.
    Ordered the AccuFab secondary kit with HD chains and tensioners and looking to buy Cloyes billet secondary sprockets.
    Placed an order for a Hogan sheet metal intake and I am considering switching the fuel system to E85.
    I know I need to find a high performance inline fuel pump to replace the Weldon 600A pump.
    Not sure, but I think the -10 and -8 steel braided fuel lines will be OK? I have -10 from the tank to the pump and -8 from the pump to the fuel rails and -8 for the return.
    I'm sure the 42# injectors will need to be upsized. 60's seem to fit the calcs but it may need 80s?
  9. #7
    Driller, If you haven't ordered the Diamonds yet you ought to take a look at the Gibtec alternative.
    Click here for the pics and story => Gibtec Billet Pistons
    These were purpose built for blown Modmotor engines from a clean sheet of paper and incorporate some attractive piston engineering specifically for blown motors.
  10. #8
    Thanks Ed. I left the shop to order the pistons/rings since they were thinking of torque-plate honing the block.
    I thought those were exclusive to the blown mod motor? Can the piston be modified for a NA 12:1 compression? This is for the 3.700 bore if that makes any difference.
  11. #9
    Quote Originally Posted by driller View Post
    Absolutely! They are custom everything. That said, this winter there is a blown modmotor that looks like it will get built with 12.5:1 compression and Gibtec will build the pistons for him. The 3.700 bore is easily accomodated by the Gibtec guys. Talk to Nick over there. Tell him we spoke and you are not blown but you do want 12:1 compression for the 3.700 bore block. He can easily take care of you.
  12. #10
    Thanks again.
    I'll check with the shop and see if they have progressed to the point of ordering the pistons yet.
  13. #11
    I'll be talking to the shop this coming week on the pistons and some other details.
    I just received word the block was torque-plate honed and this project is on the front burner (again).
  14. #12
    The block was picked up, measured and the Gibtec billet pistons have been ordered built for high compression and future nitrous application. I was told about 3 weeks to build the pistons. Heads have been sent off to Fox Lake for refurbishing. I need to follow up with Hogan's and start picking up some fuel components.
    Hopefully, this time next month, things will start coming together.
  15. #13
    FedEx made a delivery today...
  16. #14
    Newer member here. What caused the gear to fail on start up? Sorry if I missed the backstory.
    Sent from my iPhone using Tapatalk
  17. #15
    Truthfully I really don't really know but I suspect the high lift cam conspired with the flawed secondary tensioner design.
  18. Remove Advertisements
  1. FS stock 3v head complete minus cams
    By 05yellowGT in forum Engine Parts
    Last Post: 02-02-2010, 11:28 AM
  2. Wells Fargo + Wachovia minus Citi
    By ggbiw in forum The Bar
    Last Post: 10-03-2008, 04:40 PM
  3. Brake upgrade kits (minus calipers)
    By Burke0011 in forum 2005 - 2010 Mustang GT
    Last Post: 03-06-2007, 09:08 AM
  4. T minus 3 days.........
    By JohnnyZ in forum 2005 - 2010 Mustang GT
    Last Post: 05-25-2005, 10:57 PM
  5. Who has the most NA power minus heads?
    By LS2 KLR in forum 1996 - 2004 Mustang GT
    Last Post: 02-23-2004, 02:14 AM
