2015-2016 Billet Crankshaft sprocket / gears - dont let this part ruin your engine!!
Results 1 to 5 of 5
    Supporting Vendor Array Mod Mustang Racing's Avatar
    Jul 2004
    Camarillo, CA
    1,060
    Default 2015-2016 Billet Crankshaft sprocket / gears - dont let this part ruin your engine!!
    MMR has had a overwhelming # of calls from engine builders and customers across the country with broken/failed lower crankshaft sprockets. It seems the majority have been those with upgraded camshafts but many have also been stock applications. We even received a call from a MMR dealer (BBR) who had even broke 2 on the same engine. When this part breaks catastrophic failure is certain (bent valves, damaged pistons,cylinder heads etc). MMR went to work quickly on a solution and are now selling the MMR Billet Steel gear. This gear replaces the factory powdered metal gear directly with no other changes, the MMR gears are manufactured from billet 9310 heat treated material and precision made in the US by MMR. If you are building aftermarket engine, have a Ford Racing Aluminator, or rebuilding a coyote engine you need one of these!!! Retail on the Billet steel gears is $299.
    Dont let this happen to you:
    The new MMR Billet gear
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
    Jul 2004
    Camarillo, CA
    1,060
    bump ttt
  6. #4
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
  7. #5
    Jul 2004
    Camarillo, CA
    1,060
    ttt bump
  8. Remove Advertisements
  1. New Product!!! Dont let this part destroy your GT500 engine!! The problem and the fix >>>>
    By Mod Mustang Racing in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 04-11-2018, 12:30 PM
  2. Billet oil pump gears for Coyote 2011-2015 Mustang GT / BOSS - lifetime warranty!
    By Mod Mustang Racing in forum 2011 - 2014 Mustang GT and Boss 302
    Last Post: 08-07-2015, 01:38 PM
  3. New Product!!! Dont let this part destroy your coyote engine!! The problem and the fix >>>>
    Last Post: 07-15-2015, 05:47 PM
  4. Replies: 2
    Last Post: 03-19-2012, 12:24 PM
  5. Anyone used the 03 cobra double gear crankshaft sprocket on a 97 model engine?
    By white46snake in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 02-22-2004, 08:44 PM
