Aluminator Gibtec Build
448K views 789 replies 65 participants last post by  eschaider
#1 · (Edited)
Thread update: Table of Contents
Since this thread has gotten long and I've received many PM's on Facebook and e-mail with questions about the build, I figured a ToC would help anyone searching. It is based on 15 posts per page, and is also broken down in groups and now with hyperlinked post numbers. In the event some quick info is needed, this should make it easy! Also, all hyperlinks, other than the obvious cut-and-paste links are bold so they stand out and are easier to recognize, especially when not logged in.
p.1 (Posts 1-15): Short block, pistons, heads, '98 Cobra cams, bearings, ARP parts list, oil pump & windage tray
p.2 (Posts 16-30): Oil cooler gasket, block heater, head gaskets, more on ARP
p.3 (Posts 31-45): Timing components, cam bolts
p.4 (Posts 46-60): Timing cover bolt modification (aluminum block), upgraded secondary tensioner
p.5 (Posts 61-75): Cam degree tools
p.6 (Posts 76-90): Misc. chat
p.7 (Posts 91-105): Oil slinger discussion
p.8 (Posts 106-120): Oil slinger cont., rear main seal
p.9 (Posts 121-135): Rear main seal cont.
p.10 (Posts 136-150): King bearing tech from Ed
p.11 (Posts 151-165): King bearing tech cont., GT-500 rockers, timing cover hole (Cont. from P.4)
p.12 (Posts 166-180): Degreeing the cams, '98 specs
p.13 (Posts 181-195): Degreeing the cams cont., timing cover, cam follower install
p.14 (Posts 196-210): Primary tensioner ratchet modification
p.15 (Posts 211-225): Primary tensioner spacer modification (update to P.14)
p.16 (Posts 226-240): Primary tensioner spacer modification cont.
p.17 (Posts 241-255): Valve cover mock-up, exhaust manifolds
p.18 (Posts 256-270): Tensioner spacer info from Ed, ready to pull "old" engine
p.19 (Posts 271-285): Oil cooler, PCV fitting for aluminum block
p.20 (Posts 286-300): Quick Seat info
p.21 (Posts 301-315): Old vs. new piston trivia, valve covers
p.22 (Posts 316-330): New engine installed, Centerforce clutch
p.23 (Posts 331-345): Crank damper, accessory belts
p.24 (Posts 346-360): Transmission install, accessory belts cont.
p.25 (Posts 361-375): Power steering pump and A/C install notes
p.26 (Posts 376-390): First start!
p.27 (Posts 391-405): First start cont.
p.28 (Posts 406-420): Notes on PTW clearances from Ed, Vampire introduction
p.29 (Posts 421-435): Rod clearance notes from Ed, block bore information
p.30 (Posts 436-450): OE piston trivia
p.31 (Posts 451-465): Misc. oil pan discussion
p.32 (Posts 466-480): Head stud info & torque notes from Ed, wideband install, PCM harness info
p.33 (Posts 481-495): PCM connector notes
p.34 (Posts 496-510): Gauge install, oil pressure sensor, billet oil filter
p.35 (Posts 511-525): Oil and pump discussion
p.36 (Posts 526-540): Head stud re-torque
p.37 (Posts 541-555): Head stud re-torque cont.
p.38 (Posts 556-570): Head stud re-torque cont.
p.39 (Posts 571-585): Project cost sheet, Vampire install completion
p.40 (Posts 586-600): Vampire adjustments
p.41 (Posts 601-615): AFR and piston notes from Ed, Vampire gauge addition
p.42 (Posts 616-630): More from Ed on detonation, new CAI
p.43 (Posts 631-645): Vampire gauge video clip
p.44 (Posts 646-660): Dyno tune results and video clip (11/1/16), new oil separator
p.45 (Posts 661-675): Switch to Mobil1 0W-40 & UOA, piston wrist pin discussion, updated alternator
p.46 (Posts 676-690): General alternator discussion
p.47 (Posts 691-705): Bolt torque & #5 thrust bearing comments, upgraded tensioner, Whipple 2.3 on the way
p.48 (Posts 706-720): Whipple talk, new intercooler, more fuel system chat
p.49 (Posts 721-735): More on the Vampire, 4.6 vs Coyote discussion, intercooler pictures
p.50 (Posts 736-750): Eaton removed, intercooler comparison pics, Whipple installed, intercooler tech
p.51 (Posts 751-765): Some e85 talk, first drive with the Whipple and new intercooler
p.52 (Posts 766-780): Visit to Gibtec, some info on Prolong
p.53 (Posts 781-): More on Prolong, new Explorer ST to go with the Cobra.
This project had been in the works for a while: started a few years back when I picked up a brand new set of FRPP heads and a like-new Aluminator block for less than $2,000, which sat in storage until now. The smart thing to do would have been to sell the goods and make some money, especially since my OEM engine only has 21,000 miles on it, but who can resist tinkering. Adding to that, when you can make something leaps and bounds better, might as well enjoy the fruits of your labor while you have the chance.
I'll actually begin with a shot of where I am as of the date I decided to start this thread (fall of '15), but will go backwards to the early stages and update it little by little with as much tech as I can. Since there are not a lot of Aluminator builds out there, hopefully this will be helpful to anyone considering this route. Here's the long block:
Automotive tire Motor vehicle Automotive design Automotive exterior Engineering
Before moving on, I have to pass on a world of thanks to Ed for designing the finest 2618 aluminum piston out there through Gibtec of Denver, and for his willingness to help out so many on this forum with the encyclopedia of knowledge he possesses!! For those that haven't seen the Gibtec "Custom ModMotor Piston" thread, here are my specs (0.002" oversize) and pics added from it:
Gas Circle Plastic Electric blue Liquid
Camera lens Camera Camera accessory Digital camera Lens
Helmet Sports equipment Automotive lighting Sports gear Audio equipment
I also intended to add an Aluminator build page up on my own site, but for now it just serves as a link back here since this got long. For anyone curious about the Aluminator block, this Castings page has a bunch of information on what makes it such a great choice! Stay tuned, more to come...
5
#759 ·
Just as an OBTW sort of observation your build thread is the third most viewed thread on the site as of this posting. The #1 and #2 threads were started six and seven years before yours. Speaks volumes about how well the thread was conceived, organized and presented. Very impressive.
#760 ·
I dig that, Ed!
Hopefully, though, after two+ years with this thread and the other websites that have been up for much longer (and constantly being tweaked as well), I can take somewhat of a break from writing and get more time behind the wheel. Then again, I need to possibly get that Brookpark Engine Plant "special" tour to work out (would get a kick out of seeing the EcoBoost engines get built, especially since I have one as well), so that could be a decent front page story, especially if they let me bring in a camera...:)
#761 ·
Way cool Joe!
I literally grew up within about five miles of that plant. It is almost right behind Cleveland Airport. We used to call it the Berea Engine Plant. I think it was right on the borderline between Berea and Brookpark. In the early 60's I tried (many times) to get a tour of the 255 Indy engine assembly operations over there but predictably that was not to be in those days — still too much top secret stuff :)
#762 ·
You have the location of the plant correct, Ed. It's right on Brookpark road just off the NE corner of Hopkins. From my house, it's probably less than 3 miles:)
I was told I could get in to areas of the plant "...that no outsider gets to see", or something to that effect, so I might have to follow up on it. Would be neat to see where the engine in my '14 Explorer Sport was built, and even better if they'd let me snap some pics and write about it. Definitely going to pursue it again!
#763 ·
Damn!
I would be all over that offer in a New York minute, Joe. There used to be magic in some places inside that plant. I suspect there still is today. Definitely take advantage of the offer! Shucks if you don't want to, get me plugged in and I'll fly out to take your place. :)
#764 ·
Funny enough, one of my parts guys at the local dealer wants in on it, too. Might end up being a "group" tour;)
Now I just have to hope it doesn't lead me to an "EcoBoost Gibtec Build...", or something like that. Then again, I have an 8/100,000 warranty on the Explorer, so that might be incentive to leave well enough alone!
#765 ·
Just as one "final" update - car related, and not about the Brookpark plant - got out last week for about a 100 mile road trip and all is running insanely well. With the outside temperatures close to 80°, the coolant temp was usually around 176° on the expressway, and would creep up in to the mid- to high-180's when on regular roads. I'm real happy with the intercooler since the IAT2 readings would still drop down to around 110° fairly quick after getting a bit aggressive (highest I have seen so far has been about 130°). Overall, the mix of coolant components mated to the Whipple has made a nice difference in under-hood heat.
I did want to add that I may need to recalibrate the Vampire since I think the original settings were probably more in tune with the Eaton "noise" (will shoot John an e-mail and check on that). There were a couple flickers here and there of the LED's, but I noticed absolutely nothing different when it came to how smooth the engine was running, so it could have just been the air and fuel of the day contributing - especially since I hadn't added any more Torco to the last tank. If I do get out and tinker with the box soon, I may throw a short video up, but otherwise, the warm weather is here and it is definitely time to drive...
Just some more eye candy for no real reason whatsoever:
#766 ·
Nice work Joe!
I’m really curious about the change in charge air temp as the Alabama heat is really getting to my setup (Upper pulley Heaton). I’m considering an upgrade just for efficiency and to reduce power loss due to high IAT2. Wouldn’t mind a little more power too.
Do you have any before temps with the Eaton? Could you provide addition IAT2 readings at higher ambient temps.
Thanks, Todd
#767 · (Edited)
I wish I would have kept better records with regards to the IAT2 readings with the Eaton, but I want to say 120°, give or take, was the norm (may have also mentioned it elsewhere in the thread, but I’ll have to look). With this one, they can still push 130°+ if I’m really revving the engine, but once I back off and get in to a steady cruise, I’ll see 110-112° in short order. I’m sure having the twin-screw helps, but the original claims of this intercooler dropping temps about 10° or so seem to be right on.
With the location of it, heat is always going to be an issue, but it’s nice to see the temperature recover so quickly. Also, my coolant temp can creep in to the high 180’s when getting on it, but a steady cruise will always have them back in to the 170’s quickly as well. This has been on days when the temps outside have been 80-90° as well. In any case, I’m still pleased with the results all over, and glad you liked the thread!
#768 · (Edited by Moderator)
Had to add another post to this thread, especially since it's hard to believe it got started just over three years ago and is still plugging away! I really had hoped to add an update this fall with the Whipple on a dyno, but work has kept me busy which means a tweak to the tune will have to wait until next spring. No matter, the engine is still running phenomenally well and has never missed a beat, even with a couple three-hundred mile road trips back and forth to SE Michigan. At the very least, I'll put a few more miles on over the next month or so, then it is time for winter storage.
Anyway, I was fortunate to spend most of September and part of October in Denver (for work, since my company has a large training facility there), and couldn't resist taking some time to pay a visit to the Guys at Gibtec. Thanks go to owner Rob Giebas for showing me around the facility despite a busy work day for them. I probably talked to Rob once on the phone a couple years back, and when I got in touch this time, he remembered me as well as this build thread - pretty cool!
Unfortunately, I only snapped a handful of pics since I didn't want to inadvertently catch anything that was proprietary, but it was great to get over to their immaculate facility and see what goes in to their custom work. I also totally missed out that there must have been a smudge on the lens of my phone's camera, so the pictures stink (my apologies), but there are a bunch more already on the Gallery at Gibtec's site.
Here is also the original promo video that was on Gibtec's old site featuring Rob with some great shots of their machines in action:
For anyone that may be fortunate to pay them a visit, it's quite impressive to see how a set of pistons starts off as slugs then make their way around to the various CNC machines in an assembly-line fashion leading to a final product. I neglected to count how many stations there were, but I'd say at least eight were there in various stages of milling and cutting. I also got a kick out of not only seeing many sets that were improvements on damaged pistons from competitors, but the variety that they produce ranging from snowmobiles, street cars like mine, all the way up to top fuel dragsters.
The front of the building: little did I know that this facility combines Winberg Crankshafts, GRP Connecting Rods and of course, Gibtec.
Building Plant Window Door Fixture
Once you are in the door, there is a crazy long hallway that leads you all the way to the back, with the Gibtec area on the left (I didn't pace it out, but it's a hike!). Everything to the immediate right is Winberg, with GRP even further right. It's a huge building, to say the least (there are also more pictures on Winberg's Facility Tour that gives an idea as to how large the place is). Not sure why it got rotated, but you get the idea...
Lighting Fixture Flooring Wood Floor
Up in the front part of the "lab", where finished sets are packed up and shipped . The boxes are so cool that I still have my original.
Interior design Automotive design Floor Chair Table
Just a quick shot looking in to the back at a few of the CNC machines:
Lighting Interior design Floor Flooring Gas
Up front, there are also many racks with a plethora of Total Seal rings, their wrist pins, etc.:
Shelf Shelving Building Floor Retail
In another corner of the shop is where some of the design takes place. Over towards the left is a table with a cylinder head on it: this is where the do the 3D scanning (although I neglected to ask if heads are in the works for them, but some other things I saw in the shop led to me believe they have the capacity to do a lot). This is where they'd also scan the pistons that get sent in from burnt up engines to they can produce new and improved designs (I'll leave out names of a couple competitor pistons that came in with damage, leading to some amazing new sets!). There was also another room just to the left of this where the coat their pistons per customer specs, but I was in there just briefly and not wanting to breathe in any of the stuff.
Property Television Building Picture frame Shelf
Their office with a plethora of samples and prototype pistons that they take with them to shows (such as PRI). The model of Ed's design that led to mine (which was the launch set), was floating around somewhere as well. According to Rob, it gets referenced a lot when it comes to customers placing orders for their mod motors, and he even knew my customer ID - matched to that model - off the top of his head.
Building Interior design Audio equipment Window blind Barware
Couldn't leave without Rob making sure I had a couple more of their shirts with the new logo - very cool!
Product Sleeve Font T-shirt Sportswear
Somewhat unrelated, here is a YouTube video where Rob is interviewed about a relatively new advancement of theirs (the "button"). I commented on this it to Ed and he, of course, knew all about it. Just goes to show what kind of stuff Rob and his crew can turn out. As I mentioned to him, I never hesitate to brag about their work and am glad to see many others get on board with the fantastic pistons they turn out!
#770 ·
Thanks for tweaking the pic, Ed.
It was great seeing the shop for sure, and I got a kick out of Rob remembering my customer number off the top of his head (but makes sense since they were set #1)! Just too bad Nick wasn't around, but I did make sure to let him know how much their work was appreciated. By the looks of some of the other sets they were churning out, it appears they are doing quite well with customers coming over from other brands knowing the bang-for-the-buck factor Gibtec delivers (among many other reasons)!
#771 · (Edited)
Been going through this with a fine tooth comb since I am getting ready to start my own Aluminator/Gibtec build.
Going through the ARP hardware I noticed you used 12 point heads on the main studs and rod bolts but went with hex heads on the head studs. Was there any specific reasoning behind that decision or is that just a what was in stock type thing?
#772 · (Edited)
No real reason other than getting a fantastic deal for the standard 8740 set which I then traded back in for the 2000’s. ARP was great and only minimally upcharged for the newer ones which came in lower than most other prices I found out there.
#773 · (Edited)
Gotcha thanks. This thread is helping more than anything else out there right now while I’m gathering my parts. My build will be following yours nearly identical since I got my hands on a brand new Aluminator SC block and a brand new set of FRPP cnc Roush ported DC casting heads. I’m looking to bump compression a bit more since I intend to run E85 with mine.
#774 ·
Gotcha thanks. This thread is helping more than anything else out there right now while I'm gathering my parts. My build will be following yours nearly identical since I got my hands on a brand new Aluminator SC block and a brand new set of FRPP cnc Roush ported DC casting heads. I'm looking to bump compression a bit more since I intend to run E85 with mine.
Man, where'd you manage to snag those at!
#776 ·
Figured it was time for another quick update, although it's not anything exciting like a trip to the Dyno to see what the new engine is putting down (hopefully sometime this year I'll get that done!)...
I was kind of a slacker last year - although work kept me overly busy - so I didn't put a lot of miles on the car, and engine. Definitely hoping to change that this year. In any case, just over 1,500 on the engine and it's running crazy strong. Unfortunately, my busy schedule detoured me away from doing one thing that I've always been regimented on: the oil change. As much as I hate to admit it, my recent refresh of the fluid was at a two-year interval, albeit with only about 900 miles. I didn't worry too much since the frequent checks of the dipstick showed no loss (and the oil still looked clean), plus what I drained from the oil separator was not unusual in any way.
Carrying on, I did send another sample to Blackstone, but was also curious about an additive I put in on a recommendation from Ed (as if anything on this site isn't a recommendation from Ed!): a 12 Oz. bottle of Prolong Engine Treatment. Not that I needed it, and since the engine still runs crazy smooth, but I was curious how the stuff would show up on the UOA. I will also admit that I think the already-quiet valvetrain may have dropped a few decibels still with the additive, but I was more interested in minimizing as much start-up wear as possible. Ed swears by the stuff, so what could go wrong!
Anyway, here's a shot of the UOA - again with the two-year drain interval - and just under 900 miles on the M1 0W-40. There is really nothing unusual at all about it, other than maybe a slight uptick in the Boron and Magnesium, but they are typical anti-wear additives. The copper is also coming down nicely according to them and the TBN still looked great. I did see that the Ph & Zn levels had dropped slightly, but I would guess that was due to the age. Since they are still on the high side compared to most off-the-shelf oil, I see nothing to worry about.
Since nothing scary came out of this, I was planning to add a bottle of the Prolong to my D.D. '14 Explorer Sport as well. It also has a smooth running DOHC engine and is pampered, but the extra protection at start will be nice considering the winters it sees. Had not been a fan of any additives over the years, but glad Ed had convinced me to try this.
#777 · (Edited)
Very nice results for a two year check up Joe. That lab report makes the engine look like it is brand new! You are right about my feelings towards Prolong - it just works although, like myself originally, most industry professionals will prefer no additives.
Like so many of us, originally I was not an oil additive fan. Years (decades?) ago when I still lived in New England I bumped into Prolong in manufacturers row at a meet and under duress tried the additive after watching their demo.. Later that evening on a qualifying pass we blew an oil line off our Oberg filter during a qualifying run and I was certain the engine was toast.
That evening as we tore it down to do our engine post mortem, I couldn't believe how slippery all the parts were. The roller lifters were so slippery I actually needed a pair of needle nose pliers to pull them out of the block! Even more impressive the bottom end was just as we had put it together. Not even one bearing was bruised! The run the oil line came off on was a 6.40 something pass at well over 215 mph.
I have been a ProLong fan ever since and I put it in everything I have that uses an internal combustion engine. From first hand personal experience I can tell you it is just flat impressive. Bad industry oil additive PR not withstanding this is one additive I go out of my way to get and use.
After a while you begin to buy it in the larger gallon containers - it cuts the price about in half.
Liquid Purple Fluid Packaging and labeling Violet
#778 ·
Is it good for break in or should I wait till after
#779 ·
It is too slippery for break-in use. It will substantially extend the time required to seat the rings because it is so slippery. You should not use it until after you have seated the rings.
In our engines the cams are the last to get lubricant and represent a high potential wear point at first start after a period of inactivity. This is one of the nice benefits Prolong use provides to the engine. Even after long periods of inactivity the cam journals are their saddles in the heads are still very slippery allowing a cold start without potential metal to metal contact.
That same lubricity will make seating new rings very challenging.
#781 ·
Russ,
I buy mine at Amazon, click here => Prolong - 1 Gal. they also have the 12 0z bottles, click here => Prolong - 12 oz. The bottles are usually around $17 and the gallon jug is about $68, so the jug cuts the cost per treatment about in half or a bit less.
You can usually find it at your local Auto Parts store also for somewhere around $20 for 12 oz.
#782 ·
Great deals on it for sure, Ed. I had looked on eBay and found a gallon for $72, but Amazon works just as easily. My two 12-ounce bottles at AutoZone were only $20 each, but will definitely score a jug soon.
Funny enough, I just changed the oil on my Explorer and when I put the receipt in my envelope, totally spaced out that I also added a bottle of Prolong 5,000 miles ago. Talk about slipping my mind. Will definitely look forward to seeing how its UOA looks this time around since the wear metals have been higher since day one, I'm guessing due to the turbochargers.
#783 ·
Interesting about the metals wear. I would expect to see diminished wear metrics going forward.
Give me a shout next time you find your way to CA and we can get together again for some food and talk time.
#784 ·
Haven't made any updates to this thread in a while since there really hasn't been much (well, still have a desire to get the tuned tweaked after adding the Whipple), but the engine is still just purring away and running amazingly well. Definitely looking forward to some more drives, especially to get over to a dyno somewhere.
Anyway, for some fun, added another performance vehicle to my fleet yesterday (the Anniversary of Henry Ford's passing in 1947): a 2020 Explorer ST. The new 6th Gen platform is just amazing, and the 3.0L Ecoboost engine - a derivative of the F-150's 2.7L version - is just a beast. Really feels like a truck again, and with the new engine, it's like having a V-8 under the hood. Definitely a step up from my previous '14 Explorer Sport, which was just a big Taurus SHO. Even better, the ST vehicles come with a trip to the ST Experience courtesy of Ford Performance, so that should be loads of fun soon enough:)
First white vehicle ever, totally love it.
#786 ·
Definitely dig it, Ed. Lots of fantastic tech and advances in the powertrain. Can't complain about the massage function in the seats either, especially since they are ridiculously comfortable. If only the A320's were this nice!
