BMR Suspension Handling Lowering Springs for 2015-Newer S550 Mustang - SP083
Improve the cosmetic appeal and increase the handling capabilities of your S550 with Handling Lowering Springs from BMR Suspension. Manufactured from chrome silicon high-tensile spring wire, these springs are cold wound on a CNC coiling machine that can adjust the spring diameter in real time to ensure that every spring is exactly the same. These springs will lower your 2015 and Newer V8-equipped Mustang and feature a 300 lb/in front and 980 lb/in rear linear spring rate to give you a smooth ride and great looks. The BMR Lowering Springs (SP083) lower the center of gravity and allow the body to stay flat and level in the turns, giving you the best performance possible. BMR designed the SP083 springs for handling applications, but it also works well for the street. Like all BMR lowering springs, the SP083 has a LIFETIME guarantee against spring sag. Available in red powdercoat for long-lasting good looks. Installation time is about 3-4 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
