BMR Suspension Releases Camber Bolts for 2015-newer Mustang –
FC003
Correct front wheel alignment and add camber adjustability to the front of your 2015-newer Ford Mustang with Camber Bolts from BMR Suspension. The factory camber adjustability can be insufficient once your car is lowered, leading to poor handling and premature tire wear. Forged from high-strength steel, BMR’s Camber Bolts give you 2.5 degree of additional camber adjustability in the front of your Mustang. BMR’s Camber Bolts (FC003) are designed to give you unrivaled strength and precision, allowing you to correct the front camber settings when the car is lowered, or to achieve more aggressive alignment setting for autocross or road race applications. BMR Suspension designed the FC003 Camber Bolts for street performance, drag race, and handling applications, making them perfect for any street or racecar in need of additional camber adjustability. BMR Suspension’s FC003 camber bolts are available in a durable black oxide finish for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
