Knocking noise at medium acceleration, 5 speed.
Results 1 to 3 of 3
    Default Knocking noise at medium acceleration, 5 speed.
    I have a knocking noise that occurs only on medium acceleration in 1st through 4th gears, cannot hear it on fifth. No unusual noises in clutch and I can rev the engine in neutral and get no knock. I can hold it at 4,000 rpm in neutral and no noise. This is where a bad rod bearing would usually rattle. I do get the usual ford oil pump rattle when starting it first thing in the morning. Drained the transmission and no metal in oil so I doubt the problem is there. No codes but the baro reading is 28.5 consistently even when the actual baro pressure is 30.1. The knocking does not sound like pinging so I do not thing i is timing related. I bought this car used and do not know the history. Is there any way to tell if it has been programmed and if so what can I do about it? How hard is it to put bearings in one of these in the car?
    Member Array
    Mar 2014
    Spotysylvania VA
    50
    Not sure if my problem is same as yours but I would get popping in the exhaust only at part throttle acceleration, like yours everything else sounded good, I did get O2 sensor fail and running rich, found I had sticking fuel injectors.
    Will
    Quote Originally Posted by Rickf View Post
    Bearings are relatively easy to install. It is the prep that will tax you. You will need to pull the engine, disassemble it, recondition the rods, probably cut the crank 0.010" under. While you are in there, depending on miles, look at replacing the rings and re-honing the cylinders. Just for good measure, while the engine is apart freshen up the valve job, seals and springs. Depending on the condition of the pistons / cylinders you may want to investigate new pistons also.
  1. I am over loud, want medium noise now
    By metaman in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-11-2011, 12:05 PM
  2. Qa-1 Knocking Noise
    By venemous'01 in forum Suspension, Handling and Tires Tech
    Last Post: 04-01-2009, 08:51 PM
  3. Knocking noise
    By tampa03cobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-20-2007, 08:51 PM
  4. Metallic noise under acceleration
    By Boosted98GT in forum 1996 - 2004 Mustang GT
    Last Post: 03-11-2004, 07:57 PM
