Piston Interchange between 4.6 and 5.4
Closed Thread
Results 1 to 4 of 4
    Junior Member Array
    Nov 2012
    Edmonton, Alberta
    15
    Default Piston Interchange between 4.6 and 5.4
    Hi All:
    Can someone tell me if the pistons interchange between a 4.6 and a 5.4. I am building a 5.4 DOHC Navigator motor and the 4.6 pistons are more readily available.
    Thanks
    I think not, 3.55 vs.3.70 bore if I have my facts right.
    Junior Member Array
    Nov 2012
    Edmonton, Alberta
    15
    I believe the bore is the same stroke is different.
    Thanks
  6. #4
    The bores are the same and the compression heights are the same but the compression ratios are different for the same sized dish.
    Check out the Gibtec pistons in the Articles section of the site.
  7. Remove Advertisements
Closed Thread
  1. Piston skirt wear - Piston Coating solution?
    By bigmackloud in forum 1996 - 2004 Mustang GT
    Last Post: 02-01-2012, 08:01 AM
  2. computer interchange 99-04?
    By turborustang in forum 1996 - 2004 Mustang GT
    Last Post: 08-15-2011, 11:35 AM
  3. will my cranks interchange
    By yeller4.6 in forum 1996 - 2004 Mustang GT
    Last Post: 05-31-2011, 08:37 AM
  4. Interchange!
    By Screwgreen in forum Ford F-100, F-150, F-250, F-350
    Last Post: 03-24-2011, 04:57 PM
  5. Rod/Piston Interchange
    By 345 DeSoto in forum The Bar
    Last Post: 10-12-2008, 08:00 AM
