Bought a black touch that ended up with a couple door dings in the first couple months.
I was inquiring on paintless dent repair when the body shop suggested I remove the door panel, apply some heat with a heat gun and work out the dent carefully with a rounded screw driver handle. Mine was near a crease and was tricky
The technique worked perfectly except it was a bit difficult to see the opposite side of the door and work the dent at the same time, thus i had to just work the dent a bit at a time.
When using heat don't overdo it.
I hope someone benefits from this as I did
Cheers
