Tuner for engine swap?
    Default Tuner for engine swap?
    OK so I have a 4.6 3v swapped into an F100. I have a little issue right now, randomly getting Code: P060B and going into limp mode but over all it has been running great. What I'm looking for is suggestions on a tuner and a shop to help me somewhere near Atlanta. (Im in Lawrenceville)
    Am thinking about SCT PRP but I've heard horror stories about them nickel-and-diming people to death and I suspect I may have to replace my PCM. I'm not so sure I want to deal with SCT's BS.
    It was originally tuned by Delta Force but not by me. The previous owner used it to turn off pats, set it up for return fuel and who knows what else. I don't want to reinvent the wheel here so can other tuners read the PCM tuned by Delta force?
    will I loose what was already done?
    I'm looking for something that I can use for drivability not so much racing but I want access to every possible option. I also want to datalog a wideband and need suggestions on it as well.
    Senior Member Array 04DeadShort's Avatar
    Jun 2010
    Carrollton, GA
    237
    I recommend Kurgan Motorsports in Braselton Ga. Call them up and explain the situation. I'm sure he can help you out.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Thanks for the tip. Do you know if they are friendly to newcomers just showing up or should I make an appointment with them?
    Jun 2010
    Carrollton, GA
    237
    You can show up and see whats going on. They are very friendly but are usually pretty busy. Probably need to make a appointment. Kurganmotorsports.com
  1. F100 4.6 swap, Get cruise control to work? What tuner to get?
    By ibSTUB in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 05-26-2016, 03:22 PM
  2. 1971 Ford Torino v8 engine swap, but what engine??????? HELP!!!!
    By BlackRockFab in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 05-24-2016, 02:48 PM
  3. Engine builder + tuner advise needed
    By raetza in forum 2005 - 2010 Mustang GT
    Last Post: 07-01-2013, 03:12 PM
  4. Tuner Needed SF Bay Area, CA. 5.4L S/C Engine Swap
    By shaun8541 in forum Tuning and Diagnostics
    Last Post: 07-17-2012, 04:16 PM
  5. Engine wont start after Engine Swap.
    By Cal 87 in forum 1996 - 2004 Mustang GT
    Last Post: 12-01-2011, 01:00 AM
