Have a 09 GT that is very difficult to shift into 3rd gear under full throttle without missing it. Has Hurst shifter. Under full throttle I bump the clutch pedal enough to get it to release and when I go for third gear it feels like I hit a wall. Not good. Quick shifting, letting off throttle and shifting slower is OK but slows down acceleration when drag racing. Is there any other shifters or internal mods that can be done so I don't keep missing third gear. Thank you
I had the same issue and went with prothane motor mounts and a trans brace, didn't matter. Finally installed a used TR6060 and thought I died and went to heaven.
Thanks for your reply. Can I use my Hurst shifter in the new trans. What's a fair price for a used trans. Any other changes nesscary to put in trans. Thanks in advance
You will not be able to use your shifter. fleabay and svtp are good places for used 6060. You will need a driveshaft also.
Related Threads
1.8M posts
53.5K members
Since 2002
