new build process
Page 1 of 4 1234 Last
Results 1 to 15 of 47
    Senior Member Array LITTLEMAGS's Avatar
    Jul 2005
    Ann Arbor, mi
    802
    Default new build process
    Previous combo was a teksid stroked 4.6 (3.80 Kellogg crank, manley rods and diamond custom piston) COG driven procharger with 100shot....couldn't ask for more. Last year decided to switch to a standalone and got a great deal on a used FAST XFI 2.0 and pulled the trigger. Decided while it was apart I needed to upgrade my roll bar to a cage.
    Anyways...fast forward to install of XFI and we noticed overheating issues. We assumed was because I switched to a different (smaller) radiator but was actually an engine problem. I had moved sleeve #4 UP in the block. After tearing everything down I made the decision to switch to a turbo setup.
    I will update more when things move along
    Man, dumping the Procharger in favor of a turbo, looking forward to this. I've considered doing the same, but I just love the sound of the Procharger under the hood :D
    Jul 2005
    Ann Arbor, mi
    802
    this is a look at the Teksid sleeve on number 4...
  6. #4
    Jul 2005
    Ann Arbor, mi
    802
Size:  57.8 KBnew block at machine shop...upgraded rods to billet olivers and JE big bore pistons...sticking around 9.5:1...
  7. #5
    Jul 2005
    Ann Arbor, mi
    802
    Went thru Caleb at CG fab for HOT side....stainless 4v race version. 60mm wastegate flange. He made them and had to me within 4 weeks and I promptly sent to get ceramic coated....lol should have just went with mild steel...lolName:  IMG_2605.JPG
Size:  89.4 KBName:  IMG_2606.JPG
Size:  80.6 KBName:  IMG_2608.JPG
Size:  84.2 KBName:  IMG_2610.JPG
  8. #6
    I don't know how much boost you plan on running with the BOSS50 block, but I suggest using dead soft copper gaskets along with O-rings in the heads with the receiver grooves in the block. You'll need to use the figure 8 pattern with the BOSS block, but when done correctly, you won't have any issues with head gaskets and high boost on that block.
    - - - Updated - - -
    Quote Originally Posted by LITTLEMAGS View Post
    Did you have that block re-sleeved at some point? Kind of odd for the sleeve move like that, never seen it before on a stock block.
  9. #7
    Jul 2005
    Ann Arbor, mi
    802
    Quote Originally Posted by Helomech74 View Post
    - - - Updated - - -
    that is the plan with the block....and that was a stock teksid from a 98.
  10. #8
    What's the plan with the procharger setup, going to sell it all off?
  11. #9
    Jul 2005
    Ann Arbor, mi
    802
    actually sold the whole setup...once I decided on going this route I sold it. Went faster than I expected...so I wasn't asking for enough $$. I have a quite a few things to get still...I want to redo my cooling system as well.
  12. #10
    Jul 2005
    Ann Arbor, mi
    802
    Getting engine prepped for cleanup
  13. #11
    Jul 2005
    Ann Arbor, mi
    802
    More pics
  14. #12
    Which manual brake setup is that?
  15. #13
    Just stumbled across your thread, Dom. If Jim had not asked the re-sleeving question I would have. The cast in sleeves that Ford and Teksid used did not require a register at the bottom of the bore to locate them because the OD of the sleeve was intentionally left as a ragged surface to anchor the sleeve in the aluminum block.
    From the picture of the sleeve that moved, it looks like a flangeless aftermarket replacement. One of the cue's is the visual appearance of being a thicker wall than OEM and the other is the movement down the block's sleeve bore. The external surface on the OEM sleeve is so heavily textured that I would expect it to literally tear aluminum from the sleeve bore in the block to allow vertical movement.
    Although this is not much help since you have already bought the BOSS block, a very attractive fix for the Teksid family blocks is the use of flanged aftermarket LA sleeves with heavier than stock wall thickness. Here is a pic of Mofasta's block after one of those sleeve installs.
    I am strongly prejudiced in favor of the o-ring solution Jim has previously recommended for supercharged engine with our 4 bolt head bolt pattern. It sounds like you had already decided on the same solution.
    When AJ last ran his car he had to short shifted second to control a wheelstand as I recall. The additional loading it subjected the MLS gaskets to caused a pushed out head gasket failure that burned a block and a cylinder head. The copper head gaskets and stainless wire in the heads will nicely solve that problem.
  16. #14
    Jul 2005
    Ann Arbor, mi
    802
    Yeah...I was originally TOLD by my original engine builder it was not sleeved. He no longer is in business after his son passed. (JT) Soooo....anyways, the rotating assembly though looks really good though BUT being a stroker package I went against using it in my turbo build and use standard stroke but with upgraded rods (oliver billet and big bore JE pistons)
  17. #15
    Jul 2005
    Ann Arbor, mi
    802
    strange with wilwood Pvalve
  18. Remove Advertisements
  1. Spec5, break-in process?
    By abner duran in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-17-2010, 10:21 PM
  2. My build process starts tonight
    By againstallodds1 in forum 2005 - 2010 Mustang GT
    Last Post: 12-11-2008, 01:15 PM
  3. Grueling Zaino process - Round 2
    By TenaciousCobra in forum Pictures and Videos
    Last Post: 05-28-2008, 03:52 PM
  4. In the process of a cam swap. What caused this?
    By redman in forum 1996 - 2004 Mustang GT
    Last Post: 06-17-2006, 12:43 AM
