Vendor Sale!!! Oil pump gear / crank sprocket combo (11-17 mustang) $399!!!
Results 1 to 3 of 3
    Supporting Vendor Array Mod Mustang Racing's Avatar
    Jul 2004
    Camarillo, CA
    1,062
    Default Billet 5.0 Coyote Oil pump gear / crank sprocket combo (11-17 mustang) $399!!!
    Simply the finest Billet Gears available for your engine!
    This combo kit includes MMR Billet Oil Pump gears part# 400224 and MMR Billet Crankshaft Gear 467891 or 467892 (select below)
    Both Items are so strong that they feature a LIFETIME WARRANTY to the original owner!
    As used by Multiple NMCA/NMRA Champions and Record holders and by Team MMR and the Worlds Fastest and most powerful coyote engine ever! These are the ONLY parts tested beyond 10,000 rpm and 3000+ HP!! Perfect for that daily driver or the most extreme engine builds.
    Add to Cart: http://www.modularmotorsportsracing....oducts_id=1008
    Add ARP/MMR Balancer Bolt & support washer (PN#444393) ( +$29.99 )
    Add Balancer install bolt for 5.0 Coyote (tool for install only) ( +$13.99 )
    Add Stock Balancer Puller (PN#T1470) ( +$69.99 )
    Jul 2004
    Camarillo, CA
    1,062
    ttt bump
    Jul 2004
    Camarillo, CA
    1,062
    ttt bump
  1. Oil Pump Inner Gear Loose on Crank
    By 4vFoxx in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-08-2016, 12:41 PM
  2. crank sprocket galling?
    By Swerve in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-20-2012, 07:28 PM
  3. Crank Sprocket Install Issue
    By mfyas420 in forum 1996 - 2004 Mustang GT
    Last Post: 07-30-2010, 08:13 AM
  4. Cam sprocket/gear swap help
    By OLDFORD in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-28-2008, 12:40 PM
