Ingot Silver, Glass Roof, 17,500 miles, all performance mods done at 14,000 miles, Roush Upper and Lower Grill, Roush Chin Spoiler, Boss 302 Rear Lower Valance, GT500 Wing, Ford Racing 11:1 Compression Aluminator Crate Motor with Billet Oil Pump Gear and Crank Sprocket Upgrade, 12qt Oil Pan, Hellion Twin 62mm Ball Bearing Turbo Kit, JPC Triple 465LPH Fuel System, Injector Dynamics 1300 Fuel Injectors, AMS 1000 Boost Controller, AEM Failsafe Gauge, Exedy Built 6r80 Transmission, Circle D 2B Converter, MSD 2 Step and Relay Transbrake, DSS Aluminum Driveshaft, Safety Loop, UPR Tubular K Member, BMR A Arms, BMR lightweight Rad Support Bar, Strange Race Brakes all 4 Corners, Custom Front to Back Exhaust with Borla Race Mufflers, Built 8.8 with 35 Spline Axles, Spool and 3.31 Gears, Viking Rear double adjustable shocks, BMR Upper and Lower Control Arms, BMR Anti Roll Bar, BMR lower control arm brackets, Eibach Pro Kit springs, Transmission cooler, 17"Front/15" Rear SVE Drag Wheels, Pro Drag Radials, SCT X4, Tuned by Kevin MacDonald at JPC Racing....Tunes for 93 pump gas and E85-98. An 8 second time slip capable Coyote Mustang and has run a 9.49@151 while doing a few shakedown passes. Price is set at $45,000 and from the list of parts its worth it for them alone. https://www.youtube.com/watch?v=8XxpZTMc0RA
Car is located in Toronto.
