Caster/Camber install VIDEO
Results 1 to 2 of 2
    Default Caster/Camber install VIDEO
    Here is my latest DIY video. Check out my channel and subscribe!
    These are caster/camber plates- very necessary for aligning your car when you lower it or want to have more flexibility for setting your alignment for the track
    https://www.youtube.com/watch?v=MxqQ...ature=youtu.be
    Senior Member Array BlueScreen's Avatar
    May 2009
    Canada (Quebec)
    1,034
    Very nice video, I watched it all. I did this back in 2013 on my 97 GT, except I also added coil-over in the front at the same time.
    How was the alignment after everything was done ? My car was at stock height, and to get camber to factory spec, I had to adjust the camber to the full minimum. It's not much of a problem, but I expected to be able to remove some camber, especially if later on I decide to drop the car.
  4. Remove Advertisements
  1. Install of Caster Camber Plates?
    By Speeder_069 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-02-2010, 07:03 AM
  2. Caster/Camber
    By donaldtaco in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-20-2009, 08:45 PM
  3. Caster/Camber
    By Pedrocols in forum 1996 - 2004 Mustang GT
    Last Post: 04-20-2008, 11:06 PM
  4. INSTALL QUESTIONS / MM caster camber plates with stock springs
    By jimmysidecarr in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-21-2007, 07:13 PM
  5. Help MM Caster Camber Plates Install gone wrong!
    By cpu77 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-10-2006, 09:39 AM
