Aluminator main stud torque sequence
Results 1 to 5 of 5
    Default Aluminator and wap main stud torque sequence
    Is it the same torque sequence than the teksid except skipping the jack screws ? Mine is actually a late teksid with 9mm side bolt like the wap block. I only found the sequence for the teksid with jack screws.
    You need to buy Hyland's book on Building 4.6 Engines. Great reference lots of data consolidated in one spot.
    This is how I did mine and I believe Hyland indicates in his book;
    Name:  Screen Shot 2018-02-26 at 5.58.16 PM.jpg
    p.s. I use 10mm outer studs you will have 8mm studs. You can not torque them to my 10mm specs. Get Hyland's book it will have the correct specs.
    Thanks! Do i completely torque the main stud (3 steps) and then do the side bolts ? Or do step1 on main studs , do step1 on side bolts , step2 on main studs, step 2 on side bolts ect..
  6. #4
    I do studs then side bolts. You should buy Hyland's book.
  7. #5
    Senior Member Array RussZTT's Avatar
    Aug 2004
    Tampa, Fl
    1,987
    +2 on Hyland's book, lots of useful information.
  8. Remove Advertisements
  1. Torque sequence and ft/lb for oil pan?
    By Geno in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-11-2010, 11:38 PM
  2. main stud torque for teksid?
    By fasteddy03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-17-2010, 01:48 PM
  3. ARP main stud torque specs?
    By VIPERBLUELX in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-25-2009, 10:11 AM
  4. torque specs and sequence?
    By cobrasrslow60 in forum 2005 - 2010 Mustang GT
    Last Post: 12-23-2008, 12:05 PM
  5. Torque Sequence?
    By Boosted46 in forum 1996 - 2004 Mustang GT
    Last Post: 07-12-2007, 07:28 AM
