SC pulley dimensions for diy fella
Results 1 to 8 of 8
    Default SC pulley dimensions for diy fella
    I'm asking for dimensions from 6 rib belt to 8 rib. I'm modeling one piece pulley to be bolted on stock damper, and I need measures how long it must be. I know there is ready versions, but my belt drive will be custom, and I have suitable piece of aluminium for this. I'm still missing few pieces, I can't install my Eaton for measuring myself.
    Senior Member Array soap's Avatar
    Feb 2003
    MI
    2,914
    What distance are you looking for? Between face of outer ribs? Center to center? etc?
    --Joe
    something than easiest to measure accurately. Best would be measure from bottom of outermost ribs. I have extra damper that I can use during making. I have extra belts too, so belt edge to belt edge could be doable.
    Feb 2003
    MI
    2,914
    If you don't get someone else to respond sooner, I'll get you a measurement tonight when I get home from work.
    --Joe
    Feb 2003
    MI
    2,914
    I am getting about 1.800" between belts or 1.600" between outter edge of 6 rib pulley and inner edge of 8 rib pulley. Hope this helps some.
    Thanks for your help. Belt distance is better, because I have 2 different width dampers according to weight.
    I got another answer too, but there is difference, he got 1.69" between belts ?
    Feb 2003
    MI
    2,914
    Probably due to different pulley setups and different belts. I'm using an Innovators West damper with Metco ring and not all 6/8 rib belts are exactly the same width. A tenth of an inch isn't much variation.
    --Joe
  11. Remove Advertisements
  1. Replies: 7
    Last Post: 05-31-2013, 12:31 PM
  2. new fella to the forum
    By McLuvin01 in forum New Member Introductions
    Last Post: 11-18-2012, 09:04 AM
  3. waddup fella's
    By stangfreak in forum D'Agostino Racing
    Last Post: 05-02-2008, 06:57 PM
  4. Calculating boost psi with upper and lower pulley dimensions?
    By 4sdvenom in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-16-2006, 04:26 PM
Tags for this Thread
