5.4 build 80 ml turbo
Results 1 to 4 of 4
    Default 5.4 build 80 ml turbo
    I just dynoed my car wanted to share my numbers.this was16lbs of boost 14 degrees of timing on e85 on a 103 degree day.Decided to stop there it was still making good power but figuered i would probably gain two more lbs of boost under load at the track wich would put me around 850hp.My car is a 01gt.
    Senior Member Array 4sdvenom's Avatar
    Nov 2003
    Fort Wayne, IN
    4,315
    Damn lol I thought that was one weird looking graph until I realized it was upside down. Very nice numbers. Do you have a build thread you could link or a rundown of your setup?
    What rpm did you stop the pull at?
    Ken
    No I didn't document any of the build TRW Pistons 11 to 1 Manley Rod Cobra Jet crank three stage comp intake cams stage 2 exhaust cams I think Manny shut it down at probably 6500 to6700 rpms I have a cobra computer in it so I can run it up to about 73 maximum cans will allow me to go further but doesn't make much difference with the computer I was considering switching it out book more RPMs the harder it is on the drivetrain so I figured I'd keep it the way it is
  6. #4
    Senior Member Array RussZTT's Avatar
    Aug 2004
    Tampa, Fl
    1,960
    I would think it would of put more than that down.
  7. Remove Advertisements
  1. Fs: Precision turbo 67-80 gtq
    By 04turbosnake in forum Power Adders
    Last Post: 03-18-2012, 03:43 PM
  2. F/S: Gt47-80 turbo
    By SVTboy in forum Power Adders
    Last Post: 01-17-2010, 06:41 AM
  3. NEW CPE GT47-80 turbo cobra VIDEO
    By CPE turbo in forum Turbo Modular
    Last Post: 01-30-2006, 08:38 AM
  4. 2.80 vs 2.80 RR
    By broke7 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-21-2003, 08:11 AM
  5. 04 build tenative build date
    By sonicblue03 in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 09-27-2003, 06:55 PM
