My Twin Turbo Build
Page 1 of 5 12345 Last
Results 1 to 15 of 67
    Member Array
    May 2018
    Philippines
    69
    Default My Twin Turbo Build
    Hi Ed,
    i need some advice on phasing my cams, this is for a 4.6 teksid with heavily ported B heads 4.75 stoker, forged internals, adjustable primary and secondary sprockets, twin turbo in my Nash Metro. Cams are Comp Cams
    106-403-9 ...specs are exhaust 116 CL duration 232 deg and intake 112 CL with 234 deg duration.
    the car was running before an unfortunate oil pressure problem it was a slug off the line but really flies when it gets moving, any suggestions as to advancing intake or exhaust and by how much? thanks JT
    Member Array
    May 2018
    Philippines
    69
    forgot to mention My grind is XE270AH-114,
    Senior Member Array
    Jul 2006
    1,834
    Quote Originally Posted by Thunderbolt287 View Post
    Hi Ed,
    A lot more information is needed, like: Compression, valve reliefs, max RPM, shift points, turbo specs, trans, converter stall speed, transbrake, intake manifold, gearing, weight, etc.
    Those cams have too much duration to be efficient with a turbo.
  6. #4
    Hi Ed,
    Thunderbolt,
    If you have a first name I'll use it or if you prefer I'll use your screen name.
    I am not going to be able to get to your request until later this evening. Some of the items Todd has identified are important to how you phase the cams. For example PTV clearance. Todd calls it valve reliefs, I call it Piston To Valve (PTV) clearance, they are similar and they will determine the limits you have to work within when phasing your cams. I will touch more on that going forward.
    Your comments about the car being a slug off the line indicate you are lacking in low speed power. Some of that is inherent with turbochargers because it takes time for them to spool up unless you are doing a drag race type start. Which turbos are you using? Do you use an automatic or do you use manual trans like a TKO or T56? If you use an automatic what stall converter did you buy. I am unfamiliar with Nash Metro weights. My guess is your Nash Metro is somewhere between 2700# and 3000#. Do you know what it weighs. What rear end ratio are you running?
    Until your engine gets into boost it is more like an n/a engine than a supercharged engine. My first blush instincts are that those cams are not only installed on a pretty wide centerline but they are pretty big cams for one of our engines used on the street. Which actually begs another important question, is this a street car or is this a race car?
    Like Todd suggested we need a bit more information to begin the noodling out process. Let us know what you know
  7. #5
    Member Array
    May 2018
    Philippines
    69
    HI Todd and Ed I'm jonathan, I'm a New Zealander but i live in the philippines...im the only one here running a Mod motor, its primarily a Drag car that is a bit streetable.
    Ed i did read your Cam article and found it extremely interesting thank you!
    the car is a tube frame unit with the steel body as decoration, weight is 2400lbs empty +me @225. tire diameter 28.5, rear end gear is 3.80 trans is a Powerglide from BTE in louisiana it has trans brake and has a 4500 stall converter.
    engine is Teksid 4.6 now 4.75L (small stroker) ford motorsports forged crank, Manley rods and Pistons...pistons have valve reliefs on one side only, i will try to measure PTV today, Compression 8.5.
    Heads are lincoln B which we ported and polished extensively. intake is a sheetmetal unit i made myself as i could not find one to buy.
    cams are a weak knowledge area for me what i bought are these Comp Cams 106-403-9 ...specs are exhaust 116 CL duration 232 deg and intake 112 CL with 234 deg duration, Grind XE270AH-114... i bought these with little knowledge as they were advertised as being the best for a turbo car.
    Turbos are GT35 with ceramic bearings. I am aware of the turbo spool issue and have been working slowly on that...thinking of activating the ALS system on my MS3pro or adding nitrous to launch.
    Some History, i got bored with the same old formula BBC or SBC with a carb that everyone seems to run around here and wanted to show them that Ford modular is a viable deal! i got a junk yard 96 lincoln Mk8 engine and built the car around it.
    I left it completely stock apart from injectors and ECU (MS3 pro) and twin turbo....it went surprisingly well and was running great but i got scared adding boost beyond 10 psi with the powdered metal rods etc, at the same time i was building my race engine with internals mentioned above....right or wrong i went with the B heads and spent a lot of effort improving them and building my intake which turned out pretty good except i think it has too much volume (too long too inflate).
    i built the car with mid or low 8s in mind despite the short WB it handles great straight as an arrow but embarrassingly my best time so far is 11.3 .....but trap speed was 142mph , we did dyno the car prior to the oil starvation issue and it was making 590 RHP with about 12PSI of boost (weak waste gate springs prevented further improvement).
    After reading your Cam article i see that I have probably bought the wrong Cams (lucky they are so cheap ha).
    If I'm honest my the Race engine i build did not perform much better than the stock MK8 engine, so any advise you can give with either recommending better cams or making the best of what i have already would be greatly appreciated.
    thanks in advance jonathan
  8. #6
    Jonathan,
    I am going to summarize your car profile, if I misstate or otherwise overlook something please feel free to jump in and correct me;
    Car weight (w/driver) — 2625 lbs
    Tire Diameter — 28.5 inches
    Trans — 2spd P/G with stock first gear(?)
    Converter stall — 4500
    Rear end — 3.80 ratio (rear end type?)
    Engine — Teksid block
    Crank — Modified Coyote for Teksid use
    Rods — Manley 5.933 length
    Pistons — Manley 8.5:1 c/r (intake valve reliefs?)
    Heads — Ported Lincoln "B"
    Intake —Fabricated sheetmetal
    Cams — Comp XE270AH-114
    Current Phasing — unstated
    Turbos — Twin Garret GT35's w/ceramic bearings
    Eng Mgmt — MSPro or is it the MS3Pro Ultimate?
    Fuel — ?? Gasoline?
    A couple of follow on thoughts on your car;
    As a tube chassis car I am surmising it is a race car and not a street car. The Nash Metropolitans were short wheelbase cars that I want to say were around an 85" wheelbase. Short wheelbase cars in general and less than 90" wheel base cars in particular become increasingly unstable as power levels and performance levels increase. Instead of being like a long slender arrow with good aerodynamic and directional stability the short wheelbase cars increasingly become directionally and aerodynamically unstable at higher vehicle speeds. Those are a lot of words to say, be careful as you push on the vehicle's performance envelope.
    Another challenge with short wheelbase cars is how hard you can launch the car. Because the short wheelbase reduces the leverage the front wheel weight has available to resist wheel stands, short wheelbase cars need to rely increasingly on mechanical devices like wheelie bars to control the vehicle at launch. Longer wheelbase cars can benefit from the increased lever length of the longer wheelbase to resist the pinion's predisposition to climb the ring gear at launch.
    Last rain on your parade vehicle commentary; The directional stability of a long wheelbase car is largely attributable to the aerodynamics at speed. The greater the ratio of wheelbase to vehicle track the more stable the car is at speed. One of the best examples of this is a dragster and a funny car. The funny car drivers will talk about how they have to 'drive' their car to keep it in the sweet spot on the track. The dragster drivers will comment on how little effort (comparatively speaking) they expend keeping their care in the sweet spot.
    All this worry wart stuff is just to say proceed cautiously as you turn up the wick on your car's performance. You are likely to have a handful to work with as you go down track.
    A couple of additional questions revolve around the fuel you will be using, which I suspect is gasoline, the rear end the car is using and the MSPro engine management system you are using. Your ring and pinion ratio does not seem to be an 8.8" r&p or a 9" r&p. What have you chosen to use as your rear end? MSPro systems are very impressive. Are you using the MSPro, MS3Pro or MS3Pro Ultimate system?
    Your observations about manifold volume and what you called time to inflate and I would call throttle response are spot on. Smaller intake volumes will produce improved throttle response and high end performance. For a drag race car (other than high end performance) the difference is not as great as for a road race car but it is still measurable. To the extent you can skinny up the intake volume you might want to take on a winter project that sections your plenum and allows you to experiment with different plenum volumes by changing a spacer that would raise or lower the plenum floor or roof depending on how you built the manifold. If the volume is attributable to the runner length, your ability to tune this metric is all but impossible without a manifold redesign.
    The "B" heads can be modified to have impressive port volumes and very good performance. The GT500 style head is something you might want to explore going forward. The GT500 design has two significant improvements over the earlier "B" style heads. While both intake and exhaust ports offer better shapes and dimensions for high flow applications the intake port's short side radius is substantially improved over the "B" head design because of the raised and straightened intake port. A second benefit is the casting. When Ford designed the FGT and GT500 family of heads they were intended for performance oriented use on supercharged applications with a factory warranty. The original "B" heads Ford offered were designed for a n/a Lincoln Continental driven as a luxury daily driver by a senior citizen. The GT500 castings are substantially more robust than the original Lincoln "B" heads and will last longer in a supercharged race environment.
    I'll begin to work on the cam phasing question you originally raised this evening and have a first look for you by sometime late tomorrow afternoon. BTW if you have any pics of your hot rod I am sure the guys on the site here would love to see what it looks like.
    p.s. there is no reason to limit the boost on your built engine to 10 psi or so. A good initial starting point would be somewhere in the high teens / low twenties. Additionally if in fact the car is a race only car and your racing association rules allow it, methanol is the preferred fuel.
  9. #7
    Member Array
    May 2018
    Philippines
    69
    hi Ed thanks for the reply,
    Engine management is MS3 Pro..an ongoing learning curve for me but I'm getting it figured out.
    I'm running 100 octane gasoline but have Fast fuel injectors installed 160lb-hr each so can run methanol which is available here, i did wire in a GM flex fuel sensor but have not activated it yet I'm guessing when the time comes i will have two tunes one for street with gasoline and one for race with Methanol.
    The cams were installed in Std position i wanted to see how it would run before advancing or retarding anything.
    I do realize that my choice of car is very un orthodox this is because i just like the unusual and a challenge i will definitely take your advise on sneaking up on power and speed...I used to run a big block austin Healy and that was a handful until i finally got it to stick.
    i cut down a ford 9" and installed a back brace and Yukon aluminum pumpkin with strange gears and solid spool, strange 31 spline axles strange 4 piston brakes, front end is strange struts and brakes, make my own 5 link rear end that has quick disconnect coil overs so i can drop it far enough to change the tires.
    The chassis turned out very well car runs straight and true, i did do a sneaky stretch of the wheel base to 90" ...i did not want to destroy the appearance of the car so i moved the the fender wheel arches forward and aft respectively rather than stretching the whole car.
    The car has almost exact same weight on all 4 corners and its grip is outstanding so far, but that will no doubt change if and when i can make more power off the line.
    with regard to head choices...it was more of lets see what i can do with what i have already and now having build a special manifold for B heads I've kinda tied myself to that early decision...also a pair of B heads can be bought for $150 where as GT 500 are $$$$.
    After studying your cam article i would appear that one of my biggest issues is the Cam choice, if you are able to give guidance on phasing what i have to produce a significant improvement then great, but if they are really totally unsuitable i will have to bite the bullet and buy new ones!..maybe i can use the old ones in either my studebaker Hawk or 56 F100, both of which will have ford Modulars
    Oh the low boost i mentioned was just to protect my first engine which was a completely stock Mk8 engine...i did not want to grenade a good teksid block with those powdered metal rods, remarkably it held up very well.
  10. #8
    Member Array
    May 2018
    Philippines
    69
  11. #9
    Member Array
    May 2018
    Philippines
    69
  12. #10
    It is impressive Jonathan! That is the color my mind painted the car. I think it was one of the most popular colors for those cars. I love the way you maintained the original dash appearance and extended its functionality. Why am I not surprised to see mil-spec style aircraft electrical connectors for the wiring harness
    BTW very nice fabrication and build. Your attention to detail is impressive. The ride in that little missile will be nothing short of stunning. I am guessing the car weighs in somewhere around 2300 / 2500 lbs? BTW your manifold does not look as big as I expected from your description. I suspect you are pretty close to the mark with your design.
    I noticed you are still using the OEM COPs for ignition. Does the road, you might want to consider something like the Mercury Marine IGN1-A smart coils. The OEM ignition system can fall a little short of the mark power wise when igniting supercharged mixtures. The OEM coil has about 20 mJ of energy and the IGN1-A coils are around 108 mJ. While I don't think the coils are currently costing you power (unless they are used and potentially tired) they will as you turn up the wick. If I am not mistaken the MS3Pro has the ability to drive the IGN1-A coils as part of its standard feature set.
  13. #11
    Jonathan,
    There are two pics that didn't make it into your post #8. Try reinserting them. When you start to get around four or five pics in a post the bulletin board software gets clunky.
  14. #12
    Member Array
    May 2018
    Philippines
    69
    Hello Ed,
    thank you very much for your favorable comments, High praise from someone with your experience and knowledge!
    I wanted to maintain the cuteness of the car but still make it functional as a race car, it actually has great manners on the street just gets a bit hot in the cockpit as we always have 32deg C + here and getting stuck in traffic can be misery.
    Im using MSD 82448 COPs for ignition and i needed coil drivers for them (DIY autotune Quadspark units) as the MS3 pro only has a 200 milli amp per channel max capacity so yes i would need the coils with built in igniters.
    by the way the intercooler had to go due to the install of a huge radiator so i am now using water Meth for induction cooling.
    jonathan
  15. #13
    The water / meth combination will certainly cool but with the high ambient temps I suspect it will be hard to keep the charge temps below 65 or 70˚C. If you have built the fuel management system to pull charge at elevated charge temps, which I suspect you have (and should do), then the MS3Pro is taking timing away at the ambient temps you experience over there and that will cost you a significant amount of power.
    Whoever did your cage was quite a good fabricator. The tubing angles by the front roof posts mirror the OEM window pillars very closely while the remainder of the cage, for the most part, is nicely hidden behind the original sheetmetal.. Your are right about the car's appearance when all the sheetmetal is on the chassis it has the classic Metropolitan look with a hint of something no one would suspect — although the big feet in the back definitely hint at it.
  16. #14
    Member Array
    May 2018
    Philippines
    69
    Hi Ed I'm happy to say that I build the cage myself and since folks have seen the car i have been getting work from other local racers for cages and chassis, i Now have one full time worker and have trained her to be a a great welder fabricator, she's also an excellent Mechanic.
    About the only job i didn't do in house was the forward facing headers...they were made by Carlos Garcia in Los angeles, very nice work, fast and fairly priced CGFABRICATIONS.
    The original design of the car (stock appearance) and lack of space meant the turbos were sucking air from behind the radiator which was not good and to make it worse i was getting significant under hood head build up so a few months back we louvered the hood and flipped the turbo intakes upward so the will suck air straight thru the hood...waiting to test it all out when i can get my engine re assembled.
    As i recall previously on the dyno induction temp under boost with hood off were about 180F and with meth on it was instantly cool to touch the intake so about 60F
    Name:  Screen Shot 2018-09-11 at 9.20.54 AM.png
    we made some nice Bezels with mesh grilles for the air intake unfortunately can't find the picture...will have to make water drains in bottom of turbo intake and some make remove before flight bungs to keep out dirt and water.
  17. #15
    Senior Member Array RussZTT's Avatar
    Aug 2004
    Tampa, Fl
    1,981
    Very impressive build!
  18. Remove Advertisements
  1. Replies: 44
    Last Post: 10-21-2013, 01:29 PM
  2. Some photos from my HPP twin turbo build
    By whipped04 in forum Turbo Modular
    Last Post: 11-08-2008, 09:32 AM
  3. Replies: 19
    Last Post: 08-13-2005, 10:55 AM
  4. Replies: 1
    Last Post: 06-16-2005, 08:06 AM
  5. Thoughts on my Twin Turbo road race motor build...
    By Paul Bird in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 01-23-2004, 04:26 PM
