New guy from WA state. Here to look for idea's to help oldest boy with his Ranchero
Results 1 to 6 of 6
    Default New guy from WA state. Here to look for idea's to help oldest boy with his Ranchero
    Greetings all; My 16 year old has a new project... 74 Ranchero GT that we plan on dropping a 4V 4.6 into. We were able to secure a 94 Mark VIII 4.6 engine and transmission for the donor engine. Just getting started. Looking at suspension issues, and if dropping a CV K member in would solve the obvious wide 4V modular design. Still in the planning stages. Son wants to put the car on airbags and paint it Ford Ruby red.
    May 2018
    Philippines
    72
    Hi there welcome!
    As i recall the 74 doesn't have suspension towers... looks like a nice open engine bay the could easily accommodate the 4.6 so no need for the K member.
    the 94 Mk8 engine is nice but has the early B Heads with the IMRC plates for high and low speed running these work ok but are often clogged with carbon and no longer function the can be cleaned..or deleted with a Mod but that robs low end torque....do you have the engine computer and harness?
    the ranchero is a big heavy car so in stock form the 4.6 won't be an earth shaker but maybe that good for a 16 year old.
    Jonathan
    Hey Thunderbolt287,
    You're correct, no shock towers, but just eyeballing with a tape measure, it looks like the 4V might be too wide and hit the upper control arms. Won't know until we mock it up. Original Plan was to use the Mark VIII OD tranny as well. Kid's been looking/searching for Cobra style intake to replace the Lincoln setup; not sure what's out there yet. Maybe a Navigator setup? Plan on using Megasquirt to run the fuel and spark. It's a set up I've had sitting on the shelf awhile that I was saving for my 500 Caddi into my 68 Deville convertible. Already have the aftermarket O2 sensors to run Megasquirt. Last month we went to a Spokane Goodguys car show and saw a 64 Ranchero with a 2V 4.6 and it looks like it dropped in pretty easy. Hard to pass up the local pull and save; less than $300 for the 4V with tranny. It was the boy's first engine pull. He was pretty proud. Attachment 169223
    May 2018
    Philippines
    72
    Hi again
    I like the 4R70 TRANS but you will either need to retain the original Lincoln ECU or get an individual trans controller i think Bauman makes one... recently i think Holly ECU can also run the R470W.
    Megasquirt is good, I run an MS3 Pro but as far as i know it can't directly run a trans yet you would need an additional micro squirt controller with Can Bus upgrade.
    the Cobra intake will work but the Navigator intake is too wide due to higher deck height of 5.4 engine.
    aftermarket B intakes are not available, (MMR did make a few) i had to make my own ....other options include changing to C heads for which Manifolds are available.
    Good luck,
    Jonathan
    Been awhile since we've posted. Have to move the car and engine, so we dropped the 4.6 into the 74 Ranchero GT engine bay. Surprised it fit much better than expected. It's tight around the master cylinder and the left header will be a challenge. Overall, plenty of room otherwise. Happy campers!Attachment 169643Attachment 169645
    Welcome, i am new from India.
  1. Oh boy oh boy
    By 04Sloobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-12-2014, 05:57 AM
  2. New member, 05 GT Mustang, WA State
    By ReckinCrue in forum The Bar
    Last Post: 12-05-2013, 11:20 PM
  3. Help 2.2 Oldest style install
    By Z-eater in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-30-2008, 01:55 AM
  4. Anyone in Wa state want a soild axel swap??
    By fast01gt in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-05-2007, 04:13 PM
  5. Go White boy, Go White Boy GO!
    By SkylineUSA in forum The Bar
    Last Post: 03-08-2005, 03:06 PM
