Hey Guys, I've been having a miss-fire issue with my car ever since we got it back from the builder. I replaced all the wiring to the coils. I checked that they were all firing with a dummy coil light in line with the plug wire. I then checked them to see how far they would fire across an air gap and everything seems to be the same from bank to bank. To eliminate injector issues I put noid lights on them to see if the were firing and also they are brand new injectors but I wanted to be sure. I did a compression test and the passenger's side were significantly higher than the driver's side. The motor's compression is 10.7:1. The compression is as follows
I believe there is a timing issue and have started taking the valve cover of the car and timing cover. I just wanted to ask for a second opinion and to see if anyone had any other ideas.
The stock cops have limited ignition energy usually about 20 millijoules. By way of comparison the Mercury Marine IGN1A smart coils produce about 105 -110 millijoules of spark energy. Significantly the spark is a long duration spark of the type supercharged engines like.
If your boost is in the 20 psi plus range it is possible with the compression you are running, that the OEM cops will be having difficulty igniting the mixture. One of the routes that has helped is the use of smaller plug gaps. The practical limits on that approach are around 0.020", much below that gap the size of the spark kernel is getting too small to completely burn all the fuel in the cylinder.
The other thing to be sensitive to is the stock ECU. It is fairly good up to about 7000 rpm. After 7000 rpm the slow 25 Mhz cpu pretty much runs out of steam, which can cause fueling issues that would contribute to the misfire problem. My suspicion is you are testing the upper operating limits of the stock ECU and ignition coils.
In the FWIW bucket the approximately 30 psi compression difference bank to bank suggests different cam phasing bank to bank — although that will not contribute to the misfiring problem, it can cost you a few hp.
Sorry I forgot to add this is with the IGN1A coils and with a Stand alone ECU, I just kind of lost because I don't know what else it could be because I've replaced everything.
I presume you have already checked all the ECU and coil grounds so the next likely culprit is reduced electrical power at higher engine speeds. Have you data logged the misfires? If you have and the ECU collected voltage data it would be interesting to see the two plots overlayed.
Any data logs taken that recorded the misfires can be a treasure trove of how come and why for data.
We had another site member (SVT Troy) who had a shop install his cams for him. The engine 'misfired' when ever he started it and did so at all engine speeds - just like yours. It turned out the shop had mixed up either the intakes or exhausts for the right and left engine banks. I want to say it was the exhausts but I can't remember anymore. Once the cams were properly installed and phased the engine ran smooth as silk.
Ford Modmotor cams use a part number format like, YL7E-6A270-AB. The blue numbers (in this example 270) will indicate which bank the cams go on and also whether they are intake or exhaust cams. Intake cams carry the numbers 270 & 271. Exhaust cams cary the numbers 272 & 273. Cams for the driverside of the engine are the odd numbered (271 & 273) cams while the passenger side cams use the even numbers (270 & 272).
This stuff sounds confusing - because it is. When you lay it out on paper or on the floor in the garage it becomes much clearer.
The engine will actually run with (I believe) the exhaust cams swapped side for side. Troy's actually ran without PTV interference (blessedly). Pull your cam covers and check the camshaft part numbers stamped into the cams. You might just discover the same whoops that Troy did and that would instantly explain the funky misfiring.
Yeah I have a 3/0 wire to the motor mount and a 10 gauge wire directly to the coils, and the cylinder head ground is ground to a intake manifold bolt on each side. I re-did all of the wiring to the coils to the computer and a new relay from leash, new power wires and new plug wires. So that’s why I don’t think it’s wiring. Is it possible for someone to switch the intake and exhaust cam? I haven’t checked the part numbers on the cams yet but is it possible that the car could even run like that?
The misfire is all the time from idle on. The fuel in the car is E85. Also with the car idling I can disconnect all the injector wires on the passenger side and it doesn’t change any characteristics of the engine running. If I disconnect one injector wire on the driverside it will drop down on idle rpm and run rough. The plugs are brand new TR6 gapped at 28, I get the idea of the ground on the back of the cylinder head but if it works for one side theoretically it should on the other. I’ve also switched coils from one side to the other and injectors, all of this has been the same outcome.
The misfire is all the time from idle on. The fuel in the car is E85. Also with the car idling I can disconnect all the injector wires on the passenger side and it doesn't change any characteristics of the engine running. If I disconnect one injector wire on the driverside it will drop down on idle rpm and run rough. The plugs are brand new TR6 gapped at 28, I get the idea of the ground on the back of the cylinder head but if it works for one side theoretically it should on the other. I've also switched coils from one side to the other and injectors, all of this has been the same outcome.
Initially it sounds like you have a common issue across the cylinders. But 1-2 dead holes can seem the same as you progress through some of the common diagnosis. I initially had 2 coils pined opposite on mine and chased it for a minute like you are. I would assume you traced the wiring and you don't have a coil plug swapped. Or harness swapped bank to bank.
I would verify the coils are firing in order with a timing light. Passenger bank- 1 @ (crank timing 15* for me) 3@ 285*, 2@105* 4@195*. There is a spark event every 90 degrees. And again this is assuming 15* timing for cranking.
And check for temp in the primaries after running.
I’m using ProEFI, I have a temp gun I could use for temps. I will also re-trace the wiring but I numbered the wires and labeled them all as I slid them through the firewall, unless for some reason the harness from the company is pinned wrong. Also if you rev the car it seems fine but if you try to rev it back to back it will backfire.
Yeah I've got one side off already and the timing cover to check everything but just haven't had time to do it yet. The pistons have fly cuts in them for the valves so hopefully nothing has kissed my pistons yet. I believe the compression test would have yield different results if they had, unless they hit and are stuck shut. Thanks for everyones help and advice, I've got the weekend of so hopefully I get it all sorted out.
I agree about the lack of PTV interference. Had they hit, your compression would be way down on the wounded holes. That said I still suspect the +/- 30 psi difference bank to bank is attributable to different cam phasing bank to bank. While everything is apart to check which cam is where, this is an excellent time to also check the cam phasing and correct as necessary.
Although it essentially goes w/o saying, the job of phasing cams with the engine in the car is several orders of magnitude more difficult. While checking phasing is relatively easy, the actual rephasing would be more easily accomplished by pulling the engine. It is noteworthy however, that there are those hale and hearty types who are into self flagellation that have prevailed and done it with the engine in the car, soooo ...
Alright, I went ahead and did a leak down test for the heck of it and all the cylinders were less than 10%. Also when checking everything I noticed none of the timing marks line up from the chains to the gears. I've never really degreed cams before but are they supposed to be like that?
You'll have to roll the motor over several times to chase the marks, once it's has spun the chain marks rotate around the gears due to the primary gear being bigger than the crank gear. Even getting to to #1 TDC on the compression stroke won't get you there for a few full rotations.
Like Mike already said you will need to turn the engine over many times to get the timing marks on the chains and on the sprockets to line up again, Nick. The operative phrase here is many times. The timing mark on the chain will "walk" around the cam sprocket one or two teeth at a time for each revolution of the crankshaft — with translates into a lot of bull work. Thats the bad news.
The good news (if there is any) is the easiest thing to do at this point is check cam numbers to see who is where. If that checks out then you could check cam phasing in the car although it is a PITA. I have not seen an engine that would misfire for a few degrees difference in cam phasing. I have seen them misfire when cams get installed on the wrong banks and I have seen them misfire when there are electrical problems in the ignition circuits.
The easiest thing to do is check cam numbers. If they checkout then my bet is an ignition problem not a cam phasing problem. Although you can always fine tune cam phasing, the keyways and the timing marks make it pretty hard to screw up a basic install. You may not be optimized but you will definitely be in the ball park.
Today I checked all the cams, all of them were in the right spot. After spinning the motor by hand several times I was able to line up all the timing marks. I noticed that the passenger side cams appeared to be off by one tooth compared to the driverside. I check everything with a degree wheel and set everything back up and re-timed the motor. I ran out of time to do another compression test to see if indeed did make a difference. I spun the motor over by hand a couple of times also to check PTV clearance. I also made use of this time to put the Cobra Engineering secondary tensioner on :rock:
I am not surprised Nick. One tooth on the top is ~8.5˚ and that would account for the differences in compression pressures you saw. It would not create a misfire, however. That means you still have a gremlin hiding in the ignition system somewhere.
I also ohm the wires out from the coils to the computer and they are all pinned correctly, I don’t know what else it could be, I will try a different grounding point on the cylinder heads but other than that I would be lost.
Start with some basics. Check all grounds. How is the block grounded? Ecu ground? Visually inspect the harness for damage. Ohming is a step but even a damaged wire can be decent sometimes to not indicate anything. Verify each of the cylinders firing order by crank degrees with a timing light. I would even look at reloading a tune if possible sometimes the files can corrupt.
I also ohm the wires out from the coils to the computer and they are all pinned correctly, I don't know what else it could be, I will try a different grounding point on the cylinder heads but other than that I would be lost.
+1 on everything Mike suggested, that is hitting all the usual suspects. This is likely an issue that is not particularly easy to find but is likely 99.9% ignition related.
Not that I can weigh in with the same caliber of experience as the others but I had a similar experience so I'll share just in case it helps.
During my initial days of trying to get my new motor to fire, which had new injectors, I found that a few injectors were partially or completely stuck closed. It took me a night or two to break down and remove all 8 injectors but I used a 9v battery to operate them which is how I found the issues. Once they were addressed, boom. Engine fired right up. I ended up getting them flow-checked to be certain but all was well after that. Then other problems surfaced lol.
Even new injectors can stick closed, especially if they have sat unused for a while. Although a noid light will flash from the electrical signal the injector stays stuck shut. If you have one of those hand held infrared laser thermometers handy you can check header tubes for a cold tube. The lack of fuel from the stuck injector will show up as a cold tube. You'll not only solve the problem but simultaneously identify the stuck injector(s).
I will check the injectors but I swapped them from side to side and the problem did not follow to the side swapped. Thanks for all the input guys I hope to have this figured out soon but works been keeping me busy. I did check the compression again and now both banks are all the same 230psi.
Well just to give some closure to this problem, the timing was the issue and everything is running as it should now.
Related Threads
1.8M posts
53.5K members
Since 2002
