Torque Spec for Spark Plugs 4.6 32 valve
Results 1 to 3 of 3
    Default Torque Spec for Spark Plugs 4.6 32 valve
    Hey im not sure if in right area to post this so i come to you guys. I need help on the correct torque spec for an 2003 Lincoln Aviator 4.6 32 valve motor? Ive done some research and i hear should go with around 20ish if dont want them to blow out and so on.
    If you have 4 thread heads you should have the heads converted to 9 thread heads. The best way to do this is the Ford recommended Lock-N-Stitch fix.
    If you elect to not fix the heads the Ford recommended torque is 18 to 20 Nm or 11 to 14 ft/lbs for the 4 thread heads.
    Name:  Screen Shot 2019-02-02 at 8.08.40 AM.jpg
    If you torque to Ford Spec the 4 thread heads will fail sooner rather than later depending on how often you service your plugs.
    The best advice if you keep the heads as 4 thread pieces is to lightly hand tighten the plug giving it a ⅛ turn after it seats in the head.
    By far the best advice is go the Ford recommended Lock-N-Stitch route. I have attached Ford's TSB on their recommended repair for the heads.
    I always torque to 155 inlbs (almost 13 ftlbs.), never had an issue with the threads failing or blowing out a plug. I also use a small amount of anti seize on the threads of the plug before install. I've done this with B and C 4 thread heads as well as 2v heads and never had an issue.
    I still think the big issue with the threads failing is incorrect torque of the plugs, lack of an anti seize compound and pulling plugs when the engine is hot. Of course I could be totally wrong, but like I said, never had an issue after over 20 years of messing with these engines.
  1. Spark plug torque spec
    By cobranick123 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-07-2018, 07:14 PM
  2. Replies: 6
    Last Post: 03-22-2012, 07:55 PM
  3. Ford Racing 32 Series Spark Plug?
    By Jefe in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-22-2011, 11:44 AM
  4. FRPP Modular 3 Valve Zero Degree Spark Plugs
    By tmcolegr in forum 2005 - 2010 Mustang GT
    Last Post: 04-20-2006, 05:44 PM
  5. Torque Specs for spark plugs
    By mattz2000gt in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-10-2005, 07:29 AM
