Questions for ATI Dampener Users
Results 1 to 3 of 3
    Dec 2014
    133
    Default Questions for ATI Dampener Users
    Hi Guys, currently contiplating switching over to a ATi dampener but have a few questions for current owners. Does ATI make a adaptor hub to use Metco style pulleys with their dampener? Do these adaptor hubs bolt on using the three bolts already on the front of the dampener? Part numbers on dampener and hub? Anyone have pics they could share?
    Dec 2014
    133
    No one running a ATI dampener?
    Yes I run an ATI Dampener, Its a badass looking piece, They have them both for Stock Pulley cages and Metco crank pulleys. I'll soon have both LOL. The ATI is a two piece setup, two part numbers, one for the hub that presses on the crank and the other part number is for the Dampener/Pulley. These bolt together using blue locktite, instructions are provided, I don't remember how many bolts hold the hub to the dampener but its way more then 3, pretty sure its 6 bolts, its a very precise tight fit and it aint ever comin off.
    03 - '04 COBRA - WITH OEM CRANK SUPPORT 4.6L
    Damper pn: 918044 6.78" 5.5 lbs ALUM Hub pn: 916584 Steel
    I'm pretty sure this is the pn 918036 for the Damper that uses the Metco pulley.
    15 minutes later, Geez aren't you kids suppose to be google search masters?
    Go to this link, http://www.atiracing.com/products/da...ts/damford.htm
    Scroll down to where it says "Ford Serpentine Dampers" the very first number next to where it says 96-04 Mustang GT & Cobra is pn: 918036 and it has the little red "6" after it. if you scroll down a little more you will see on line #6 that its says its the damper that uses the Metco pulley setup.
    Ok Good luck buddy, for the Money you can't go wrong with an ATI damper, Ive had BHJ and thats also a good damper. ATI makes some of the finest parts in the industry that are ran on some of the fastest cars in the world.
  1. 10% o/d ATI Dampener
    By cmher18 in forum The Bar
    Last Post: 05-20-2010, 10:19 AM
  2. GT500 Balancer/Dampener Removal and Installation of IW 10% OD Balancer
    By Justin@VMP in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 03-23-2010, 09:59 AM
  3. WTB:Innovators West 10% dampener
    By Cookieman00x in forum Engine Parts
    Last Post: 01-30-2008, 04:29 PM
  4. NIB March SFI Fluid Dampener Underdrive Crank Pulley
    By Jamie R. in forum Engine Parts
    Last Post: 12-13-2007, 02:40 PM
  5. Innovators West Crank dampener 7.5in.
    By redstanger in forum Engine Parts
    Last Post: 11-28-2007, 02:26 PM
