Re sealing a canton oil pan
3K views 1 reply 2 participants last post by  eschaider
#1 ·
When I first installed a Canton oil pan in my 2001 Cobra, I followed Canton's instructions that called for using sealant between the engine block and the windage tray and a gasket between the windage tray and the block. Unfortunately, A leak developed and it became an irritation that needed to get fixed. The repair involved using two oil pan gaskets and Im happy to report that after a mouth of driving, the oil pan gasket area is as dry as a bone.
Interestedly enough, Ford service documentation for the 2000 Cobra R also says to use two gaskets. Perhaps, Canton is wrong to suggest using sealant?
Ford service procedure
some photos of the oil pan leak repair job.
Automotive tire Motor vehicle Bumper Vehicle Automotive exterior
Motor vehicle Hood Automotive exterior Automotive tire Automotive design
Automotive tire Hood Automotive fuel system Automotive design Motor vehicle
Wood Font Gas Rolling Electric blue
Hood Circuit component Hardware programmer Passive circuit component Computer hardware
Automotive lighting Hood Automotive tire Automotive design Motor vehicle
The quicktime bell housing bottom bolts caused a minor interference but once they were removed, a long allen socket and 10mm socket were used to remove the rear oil pan fasteners.
The Maximum Motorsports K member dropped easily and there was no need to remove the coil over kit or control arms.
See less See more
8
#2 ·
The double gasket fix you have settled on Jan is the time tested, best fix whenever a windage tray, oil scraper or other device is secured between the oil pan and the block. I doubt you will experience continued oil leaks going forward.
