Putting the motor together and ordered a set of each King MB5281SI and King MB5219SI
Am I suppose to use both the upper and lower #5 flange bearing from the 5219 set, or just the upper from 5219 and the lower from the 5281?
I noticed the one lower from the 5219 set has the tang on the wrong side and wasn't sure if i need to grind a small notch for the tang or use the 5281 lower which has the tang in the correct spot.
