Results 1 to 15 of 32
11-19-2019, 12:49 PM #1
- Join Date
- Nov 2019
- Posts
- 28
CPR CHP Brand New 600hp short block. Thrust bearing failure 1k miles in
All, Someone directed me to modular Fords in another post. Appreciate any direction/help.
Post is kinda long, I wanted to try and not leave anything out.
In Short I have a suspected rear thrust bearing failure at only 1k miles in on a brand new engine, I had no issues with the same trans/TC on stock boosted motors, the only difference here is:
new motor - 4.6 2v. built for 600hp
new flex plate (americanmuscle_com/sr-flexplate-6bolt.html)
Rebuilt TC new for new engine(but worked fine for 4 years prior in 2 different stock motors). Im still going to send it back to them for inspection.
I know we are all guessing for the most part, but maybe also basing the guessing off of previous experiences or knowledge.
Thanks in advance to anyone that reads this and/or responds ha.
Long Story
Im being told its my torque converter(custom edge racing 3200 high stall) or trans (4r70W rebuilt level4 from Darrin at BCA a god father of these transmissions). Ive ran this transmission and torque converter in 2 stock engines for over 5 years, never heard of a thrust bearing in my life or had any similar failure. I had the torque converter rebuilt new for the new engine/build.
The one engine took 150k miles of hard beating from me personally (250k total on the engine total), running hot, over heating, rich/lean tunes. Ran 2.5 years of that boosted. I eventually blew a rod or lifer. I always had mild emailed tunes from one of the best tuners for these cars. I got a used engine (supposedly with 30k Miles). I then went and got an actual dyno tune (a bit more aggressive then my emailed tunes). That engine lasted almost a year of beating on it and over heating.. but I blew the head gasket (and after tear down, I had a cracked lifer bore).
I wanted to do everything right this time, so I paid a proper race engine builder shop to build out the short block for 600HP, upgrade some things in the heads, cometic head gaskets. ARP everywhere possible etc.. any time there was a question or concern I upgraded/bought it. I had it installed from the same shop, to avoid any issue there.
After 200 miles, I got the first oil change (new filter too). I then put another 800~ miles going back and forth to the engine builders and other shops, resolving exhaust leaks (after market CATs didn't mesh well with the OEM studs on the exhaust manifolds). The car was also always running hotish on freeway runs when it never did this before. Eventually get everything going, dyno tune scheduled and.........
I hear what I think is another exhaust leak, but it ends up being a tapping from the flex plate on the metal gasket in-between the trans and engine. The engine builders are telling me to take it to a trans shop, so I take it there, they confirm it is coming from the flex plate but is too busy to put it on the lift and says he wouldn't worry too much about it, but to see if I can get it looked at by another shop.
The car is also starting to crank slow, I checked a random spark plug, and it looked fine. I think maybe the starter is slow and hitting the flex plate or sliding out, so I had the starter replaced.. sound was still there. we slightly bent the metal gasket between the engine/trans and the noise went away. I was relieved and thought the problem was solved...
20 minute test drive, all good, 20 minute ride back and things start to go bad, Im losing power, loud tapping/knocking and for the first time ever the car registers misfires in cylinder 4 and 8 (just 116 misfires and it wasn't growing) but still there. The car also was running coolant temp HOT (even though it was a 60 degree night, with highway speeds).
I instantly pulled over, turned the car off, towed it home, then back to the engine builders. Its been sitting there waiting for them to take apart. They did say the oil was very dark/black. Which Im not sure how the trans/TC would cause that at all.
Ive reached out to multiple engine/trans experts who all don't believe it was the trans( the trans has its own internal thrust washer and the pump is mounted to the trans cast internally), highly doubtful its the TC balloning (from its size and anti-ballon plate and 4 years of no issues). Engine builders are sure its trans/TC. What should I be looking for? oil starvation maybe? what else would be damaged internally that definitely would of not been from a Torque Converter? Im thinking what ever caused the thrust bearing failure is the same reason the car was running hot on freeway runs (even on cold nights with no aggressive driving at all).Last edited by shipracer; 08-25-2020 at 01:16 PM. Reason: Updating Title
Sponsored Links Remove Advertisements
11-19-2019, 02:30 PM #2
Thrust bearing failures in automatic trans cars are usually the torque converter being pushed forward on the trans input shaft and in turn pushing the crank up against #5 thrust. The fix is the transmission builder turning down the pressure forcing the converter forward.
Engine builders that do not want to be bothered will take your car and set it aside allowing it to sit until you raise a big enough stink they decide to work on it. When they do they will tell you whatever they found was your fault and it will cost you $XX to repair it. These types of shops usually promote how impressive they are, in order to get your business. You will not usually realize how unimpressive they are until something goes bump in the dark and they announce it is your problem.
Bad driving manners are almost always the tune. I would revisit the tuner and ask for help there.
Thrust bearing issues are not associated with over heating. Bad tunes and cooling system problems are associated with overheating.
All other issues not withstanding, a dead thrust bearing means the engine must come out and be rebuilt.
EdLast edited by eschaider; 11-21-2019 at 03:29 AM. Reason: Spelling and Grammar
12-02-2019, 01:17 AM #3
- Join Date
- Nov 2019
- Posts
- 28
Test post.
12-02-2019, 01:28 AM #4
- Join Date
- Nov 2019
- Posts
- 28
Not sure what happened here, I wrote a big reply, it said something about being pending moderation, been waiting days. Tried to post in another thread and it let me so i tried here again.
Ed, super appreciative of your time and reply. Every post i read on here, your the man with the knowledge. Dead on about the engine shop.
Ive talked with my transmission builder([email protected]) in great detail about the problem, he doesn't believe its the trans at all, unless some cooler line was pinched (but i was not having any transmissions issues, trans temps were great) and I ran this tranmission for almost 5 years in 2 motors, 2.5 years of that boosted without any thrust bearing issues... with the same torque converter. Same as my torque converter builder Andre (edge racing) doesnt believe it was any type of balloning with my setup, size of converter and anti-balloning plate.
Though I will have the TC inspected as well as the trans.
The car had some type of heating/oiling issue from the start I believe. I know your saying cooling is tune/cooling system but everything was brand new cooling wise, it was a cold cold night. Any highway driving (I have 4.10s also) even on a cold night the temps would just rise and rise, Ive been driving these engines for 10+ years in all conditions and never had one over heat at night let alone with 70mph cold air blowing across it. 7+ tuners, 2+ engines, probably close to 50+ total tunes if not more across the years... running rich/lean/blown head gasket.... etc..
It seems to be something with oiling was off from the start then just keep getting worse and worse as the engine shop was having me take it to 4+ other shops, anywhere but them). I started to tear down, hoping to have the engine pulled this week. Anything special I should be recording in part of that process? I was going to record the unscrewing of the TC, see if the TC slights forward at all? Not sure here, ill just try to document and document... If the TC is stuck/warped in..checking for trans dowel pins, marks on the TC hub
Cylinder 1-4 Borescope video: https://drive.google.com/open?id=1P6...yl71dmvHwg1G2g
Cylinder 5-8 Borescope video: https://drive.google.com/open?id=1PA...qx0JvfdHXqjoeo
Spark plug at 1k miles on the engine, just before its last drive later that night.
Picture: https://drive.google.com/open?id=1PT...T8-lCvrrbms9UB
Spark plug at 1015-1030~ miles after a test drive later that night.
Picture: https://drive.google.com/open?id=1PJ...g5vdGzLeo_mP9Y
01-13-2020, 09:36 PM #5
- Join Date
- Nov 2019
- Posts
- 28
The update so far, is still no cause for failure. Some kinda of pressure only on the back side of the thrust bearing (TC clearance? something internal to the engine?) I don't know. The second oil report states coolant contamination... how could that be from a thrust bearing being pushed from the trans/tc? or would all that bearing material blow out the head gasket? or some seal?
Oil Report at 210 miles first Oil Change: Screenshot
Oil Report at 1110~ miles: Screenshot
MMR says it was the trans side of the thrust bearing only worn (which then those pieces chewed up the other bearings).
Trans/TC/Flexplate checked out fine. Only thing Im thinking is the TC clearance was too tight on install?
CHP said the TC clearance… had about .080-.100” installed.
Transmission Builder - That’s tight for sure. But with a converter that has a strong balloon plate, that shouldn’t be much to worry about. Specifically, if the converter builder found nothing wrong, as long as the converter spins freely in the pilot then you should be ok unless the converter balloons. With the converter being ok, how could it be anything on the other side of it? The converter sits in the middle and would certainly show at least something. So would the flexplate. But, again, the transmission can’t do that.
Torque Converter Builder - .100 will do, but you should be seeing between .150-.180. I build all AODE/4R70W to stock heights. A thicker flex plate my be the problem, but if you don't rev over 7500 rpm, it will be fine.
01-14-2020, 02:50 PM #6
Listen to your torque converter builder and keep an eye on your charging pressure.
01-14-2020, 03:09 PM #7
- Join Date
- Nov 2019
- Posts
- 28
The torque convertor builder said its definitely not the TC and doesn't believe its the transmission either (he saw nothing wrong).
I took the flexplate and stock flexplates down to a transmission shop, they went into great detail measuring the flexplates (things are slightly different but all okay to them). They strongly dont believe it was the transmission, torque converter or flexplate (going as far as telling me it a waste of money and time to DYNO the trans but they will do it if I will pay). The transmission will be DYNO'd soon here (2 weeks or less) for only $150 dollars, the original engine builders were trying to charge me $1000 to do that.
The charging pressure will be verified soon. Once that all checks out then what? Say in a perfect world, there is nothing wrong with the transmission/TC/Flexplate.
What else could cause this damage in a brand new engine? What else do I continue to test/do? How do I not put everything back together again and have the same issue?
Im working on getting pictures of the thrust and bearings for others to see/help as well.
Im leaning towards the TC install clearance just being too tight, or something internal to the engine build. But Im guessing from all the answers/testing of everything else.
Also, thank you very much for replying Ed, your the man when it comes to this stuff. appreciate it.
01-14-2020, 04:31 PM #8
Do you have one of the MMR 4.73L (289 in3) engines that uses a modified Coyote crank?
EdLast edited by eschaider; 01-14-2020 at 04:35 PM. Reason: Corrected displacement
01-14-2020, 04:35 PM #9
- Join Date
- Nov 2019
- Posts
- 28
My engine was NOT built by MMR, it was tore down and inspected by MMR (awesome guys) and to be rebuilt by them if I can find the cause of failure.
CHP built my engine.
I had a 4.6 2V motor, built out to handle 600HP, stock crank I believe, custom pistons etc..
01-14-2020, 04:36 PM #10
Iron block or Aluminum block?
p.s. It is not your job to find the cause of the failure. It is the engine builder's job. If you are being asked to do this, it is a very big red flag. Your job is to pay for their expertise in these matters and pay for the rebuild not to science out what happened.Last edited by eschaider; 01-14-2020 at 04:43 PM.
01-14-2020, 04:41 PM #11
- Join Date
- Nov 2019
- Posts
- 28
Iron block, aluminum heads.
01-14-2020, 04:45 PM #12
If it was an aluminum block I was going to suggest a one piece rear thrust upper. They don't fit iron blocks only aluminum blocks. That said a multi piece thrust bearing should still work if the end play on the assembly is in spec.
If you haven't already, read my PM.
01-14-2020, 09:19 PM #13
Dan Golsdorf (Silver Fox) built my 4R70 and just for reference the line pressure in my trans is locked (not variable) and it runs 220-240 around 3000rpm. My converter is a multi-disc, lockup unit rated for 1500hp with anti-ballooning plate.
I have to believe that the oiling to the t-bearing is fine in the motor. Ed would know more than me about anything that "could" be limiting the oil to the thrust but assuming that it's correct then it has to be the trans/converter. This thought path would lead me to the converter ballooning for some reason.
Ed, if there isn't a ballooning plate in the converter do you know what type of line pressure would cause the converter to balloon "too much"?
What about the lockup portion of the trans/converter..what if the system wasn't matched properly.. LU with a non-LU rebuild...? I dunno, just tossing junk in the air...
You had the converter and trans rebuilt and right there I would think something didn't get put back together according to plan. Try a stock converter to see if that lasts..
What trans controller are you using?
If the two "teams" (trans/motor guys) were close I would get them together and see if they can come up with a solution.
ksLast edited by KEVINS; 01-14-2020 at 09:22 PM.
01-14-2020, 09:40 PM #14
- Join Date
- Nov 2019
- Posts
- 28
The trans was not touched or rebuilt. its the same transmission for the last 5 years (and converter i just had the converter rebuilt new, for the new engine).
I reached out to [email protected] Fox, as I have so many people for this. He was super nice and helpful. He agrees that the transmission probably has nothing to do with the issue. He mentioned I have no manual valve body, no high line pressure, no trans brake..
Same as my trans builder and TC builder we would see evidence of the pressure on the trans side too. It wouldn't magically just push on the crank. I took the flexplate and story down to Art Carr transmissions and they agree with everyone else that its not the trans/tc/flexplate. The did say they dont think there is any problem using my stock flexplate it should hold up fine, they think the other one is overkill for my needs.
I also spoke with Ed on the phone a bit today.
I'm leaning towards something wrong with the engine build/install. I believe the Thrust bearing clearance was too tight (0.007), the TC install clearance was too tight(had about .080-.100” the had about part is scary this came direct from the engine builders), and the result is what I got.
My next steps are to have the trans dyno'd to prove its line pressure (required by the original engine builders) so they can maybe re-do the short block. (but not sure if thats even worth it). From that point I may just throw a stock used motor in the car, tune down the tune a bit to keep the headgasket in placeand slowly rebuild one in my living room.
I also think the block may have some hairline crack that was not found, since the last oil test showed coolant in the oil (though maybe the head gasket let go with the crank walking and bearing material everywhere... dunno).Last edited by shipracer; 01-14-2020 at 09:43 PM.
01-14-2020, 09:50 PM #15
If it were not for the fact he had put essentially 100K miles on the converter and trans w/o thrust bearing failure, I would be more inclined to look at the trans and converter, Kevin. I am increasingly of the opinion that the engine shop erred somewhere in the assembly of the new engine.
W/o any other changes other than a new engine into a car with 100K+ on the clock and no problems, I suspect the origin of the whoopse is somewhere in the engine.
